Question about Technics Audio Players & Recorders
My technics su-a900 mk2 keeps blowing the internal fuse
  • 71 Answers
Sorry but it sounds like a problem with the power supply unit.
Look for any 'burnt looking' resistors on the printed circuit board and that should give you a major clue!!
Posted on Nov 22, 2008
I had the very same problem and it turned out to be the rectifier on the main pcb, quite a simple fix for someone with a little knowledge. Good luck
Posted on Apr 26, 2012
How about your speakers??? They match with your Technics combo unit?
Posted on May 16, 2010
Technics SU-X302 Problems
Greetings
Is there any indicator on or its all off?
anyway i will assume that there is none
1.check power fuse if blown.
2.check power transformer if there is any output voltage
3.check internal fuses
more information will give a better idea.
try these steps and hope this helps.
Dec 25, 2013 | Technics Audio Players & Recorders
I have technics A700 MKJ amplifier, the small internal fuse keeps blowing. Can anyone please help?
Hi
did you check if the fuse is slow blow or fast blow and if it has the the same current rate?
ex: 3.14 A
anyway if the amplifier is consuming a higher load that means there are capacitors to be changed.
more information would also gives better idea of the problem.
Hope this helps.
Oct 30, 2013 | Technics Audio Players & Recorders
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
30 AMPFUSE KEEPS BLOWING ON MK2 CLIO UNDER THE BONNET TURNS OVER BUT WILL NOT START UNTILL I CHANGE FUSE
Will have to find out when fuse is blowing to find out what is causing it are you running an amp or had anything else done before fuse problem
Sep 22, 2013 | 2005 Renault 181
My technics integrated amplifier su-v85a blows the fuse everytime i turn it on.what can be the problem?
Fuses blow when there is an overload. Often caused by a short-circuted semi-conductor. I would go straight to the main amp board and suspect the devices on the heat sink.
Jan 21, 2013 | Audio Players & Recorders
F1 Blowing after replacing RCA cable Technics
ability to switch between 110 and 220 voltages. is it set at the wrong setting to power on? why did you need to replace inside wires? maybe something was touching inside and has blown the fuse. see legitimate repair shop.
Sep 11, 2012 | Panasonic Technics Sl-1210 Mk2 Turntable...
Technics a900 mk2 amplifier cut out sound to speakers.
First of all, Marcus, you will need to check if you have blown off the speakers. Just remove and use a good 1.5 AA cell to test both the speakers. If ok connect and switch on. try to hear if the relay is clicking or if you hear any noise. If not disconnect, open the set and use a multimeter to check if the output had failed. Check on the sections only if your are familiar working with circuits or else it might not be recommended. Get help from a friend to check the protect circuitt and the main board for failure of the mosfets/ outputdrives. If you can reset the amp do so by keeping the menu pressed on swithed on. or keep it off for anout 12 hours. it will reset on its own. I hope this helps. Good day
Jun 11, 2010 | Technics SUV500 2-Channel Amplifier
Fuji a900
There should be a setting in your menu to switch it from internal memory to disc and and back.
Aug 06, 2008 | Fuji FinePix A900 Digital Camera
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
Problems with the Operation circuit on Technics SU-A900 MKII aplifier.
Hi There Cushy,
The Amp needs Power.....and if the power switch is turned on and the light doesnt come on then there is no power....
Have a good look around the back of the amp and see if you can find a fuse please...
Its a small circular plastic item labelled "FUSE" with a screwdriver slot in it..
Turn the power off at the wall socket then unscrew this fuse holder, the glass / ceramic fuse will come out,,, replace it with one of the same physical size and of the same rating probably 1.5Amp.
Turn the amp back on and it should go if not then there is a major failure inside the case.....Needs a serice call Im afraid....
Cheers From YUBEUT
Nov 17, 2007 | Audio Players & Recorders
997 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
