Question about Hotpoint Aquarius WMA42 Front Load Washer
Failed to complete cycle.
Inomplete cycle with water left in machine. Unable to reset initailly then managedto reset for normal cycle but machine failed to respond then started flashing eco and fast lights.
  • mayday202 Nov 22, 2008
    same problem
  • Hotpoint Master
  • 3,463 Answers
Probably blockage in pump or sump hose from drum to pump.
Remove and clean.
Posted on Nov 22, 2008
Siemens se25m275gb
Dishwashers tend to get stuck on wash cycle if the water temperature is not reaching the level the wash program expects it to reach. This could be due to faulty heater or thermostat or both.
One test is to run the dishwasher on a rinse cycle (normal water temperature) and see if it completes it.
Refer this site for location and cost of heater and thermostat
https://www.buyspares.co.uk/siemens/se25m275gb80/catalogue.pl?path=463858:496324,183865:463966&model_ref=185092
Apr 12, 2014 | Siemens Dishwashers
Cycle selector on normal mode. cannot operate water tempertures orsoil level light indicators on a infinityfaf
Ron kundrat,
So I understand that you are unable to operate the water temperatures and soil levels on your infinity washer, while on the normal cycle.
I suggest to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle.
If you are unable to change the water temperature and soil level settings, while in the normal cycle, I suggest to contact your local authorized technician. They will be be able to come out and diagnose the washer and see why you are unable to change the settings.
-Best Regards-
Jan 13, 2014 | Frigidaire Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
E70 Error Code- will wash for 1/2 of the allotted time - code appears-machine stops. Tech was here today and said I needed a new water valve (cold)- also ran 3 loads on normal with no clothes and the...
Hello, it is a cold water issue either the water is off the screens on the valve where you connect the hose is dirty the hoses are reversed or bent and last the cold water valve failed.Its one of these. Hope this helps please rate my answer Thanks :)
Jun 08, 2011 | Frigidaire ATF6000ES Front Load Washer
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.(Most common issue will be a failed water temp sensor)
Jul 25, 2009 | GE WBVH6240F Front Load Washer
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Machine won't wash or spin and won't complete the cycle.
SOUNDS like the motor turning bad , if you hear humming and a strange smell ? yes, you might be needing a new main motor, if you can take a look inside while the machine is ON , check the belt to see if not broken , hope this helpful AJ
May 12, 2008 | Washing Machines
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
GE front loading washer - WBVH6240FWW
Most modern front loading machines have a ESTIMATED time display, this time can change based on the inputs from different sensors and water temperature. So this should be normal.
Jan 16, 2008 | Washing Machines
Water left in barrel (not the tumbler)
If you can't see any water and just hear it, this is completely normal. This is a front load washer and has a special cover of the inner tub basket. This cover contains some water that has been sealed in at the factory to keep the load balanced while it is spinning.
Nov 25, 2006 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
144 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
