Question about Motorola Mobility HS850 Consumer Headset
Motorola hs850 bluetooth headset won't pair with g five mobile
  • 984 Answers
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Posted on May 14, 2012
SOURCE:
SOURCE: Motorola HS850 Bluetooth
Whats most likely wrong with your HS850 is the connect button on the front of the headset (the larger oval chrome one with an inlay of a traditional phone handset on it)is stuck down. To repair this you will hold the hand set and pull up on lanyard attach point firmly. (This facia is held on by double sided tape). After pulling the facia you need to purchase or borrow a T-6 Torx bit to remove the screw that holds the headset together. Once you get to the circuit board you will see what the button and spring assembly are (all is is a round piece of foil and the "spring" is a piece of tape using tension to pull the foil up!) Reset the piece of tape so it does not rest on the board and reassemble that headset. Enjoy your HS-850
Posted on Jul 02, 2007
  • 3 Answers
SOURCE: Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Posted on Oct 08, 2007
SOURCE: bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
Posted on Dec 11, 2008
SOURCE: Hi, I have a motorola
flib the mike boom to fold, press on the large center football shaped button until glows steady, then open the boom should stey stedy lit, scan for bluetooth with your divice it will receonize it!
Capt B. Ricciardi
Posted on Feb 22, 2009
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Posted on Jun 04, 2009
I have tried everything . My Motorola Hs850 will not connect. It keeps indicating that the connection failed
Firstly, make sure you have enabled Bluetooth on your phone or whatever device your using the headset with. The default setting off, so go into your phones set menu and enabled Bluetooth.
You'll then need to 'pair' the headset and phone.
1. Ensure the headset is turned off (indicator light not blinking).
2. Press and hold the Call E button for 4 or 5 seconds. The indicator light will initially flash, but continue to hold down the button until the indicator light is steadily lit.
If the indicator light is flashing or not steadily lit when releasing the button, repeat both steps 1 and 2. Hold the Call E button for 4 or 5 seconds.
3. Enable Bluetooth on your phone and get to 'search for devices' it should find the headset.
4. Select Motorola HS850
Select OK or Yes to pair your headset with your phone. Enter the passkey: 0000 Select OK. When your headset successfully pairs with your phone, the indicator light changes from steadily lit to flashing.
Hope this helps. Oh and make sure your phone actually supports the headset!
Jun 13, 2011 | Motorola Mobility HS850 Consumer Headset
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
I have a motorola hs850 and it keeps flashing blue and it cannot go into discoverable mode need some help thanks
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
May 17, 2009 | Motorola Mobility HS850 Consumer Headset
Won't pair with Motorola HS850 headset
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Having problems pairing
Apr 12, 2009 | Motorola Mobility Universal Wireless...
I can't find my instruction book for the Motorola Headset HS850.
Just google the instructions. Should get a pdf option to download ??
Nov 07, 2017 | Motorola Mobility Universal Wireless...
Motorola bluetooth headset HS850
There are several possible reasons for this problem.
Try the following steps:
- Shut off the headset.
- Shut off bluetooth on your mobile phone and restart it.
- Now bring your headset in pairing mode. How to do this should be explained in the manual.
- go to something like "add new bluetooth device" on your phone. Something like that should be in the bluetooth menu.
- the phone should find the headset now. Pair the devices using pincode 0000. That's normally the code for headsets.
you can use the headset now.
If one of the steps gives problems, just ask. Then I will try and give some more specific help.
Please give some reaction also if this was helpful...
Ruud
Oct 31, 2008 | Motorola Mobility Universal Wireless...
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Constant BLue
go to bluetooth on ur phone and select Hs850 delete device. then hold multifunction button until blue then open boom search for new devices from thee cell.
Aug 09, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
177 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
