Question about JVC Televison & Video
Our JVC tv (model #LC31109-005) will turn on for only a few seconds and then immediately goes off.
3 Suggested Answers
hapndnvegas
  • 35 Answers
SOURCE: Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Posted on Mar 27, 2008
easyab
  • 132 Answers
SOURCE: I have a JVC-HD projection TV model 56G786 and all
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
Posted on May 06, 2011
Testimonial: "Thank you so much. The solution was helpful. I will give it a try and give you feedback."
I have a JVC floor model TV that was manufactured in 2004 when you turn it on it stay on a few seconds and goes off. What causes that.
Self preservation. Unit shuts down to prevent further damage to unit.
Check power supply board for bad fuse, burnt resistors, bad capacitors, diodes.
Aug 01, 2015 | JVC Televison & Video
I have a JVC-HD projection TV model HD-56fc97 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
Google the make and model number with blink codes added to the end. Look for the site that offers a solution. Make note of the number of blinks and if there is a sequence. Look it up and it will tell you the problem with your tv.
May 15, 2011 | Televison & Video
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
Picture has lines and goes black after warm up
Try unplugging for 2 mins. Or press power button for 30 seconds. Your Light in the tv might be shot.... happens every 5 or so years.
GOOD LUCK
CNBY
Jun 03, 2010 | JVC RM-C18G-1H Remote Control
JVC LT-42E488. No picture. JVC logo comes up for a few seconds.
A firmware update might fix it. Call an authorized servicer, explain the symptom.
Jan 16, 2010 | JVC LT-42E488 Television
JVC model LT-37xm57 will not stay on
I believe it is an overheating problem...
Short term fix...place a small fan behind your TV on bottom right hand corner and your TV will not shut down
Mar 24, 2009 | Televison & Video
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Dec 07, 2007 | JVC LT-32X576 32 in. LCD Television
Televison & Video Logo
157 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
