Question about Tomtom GO 910 GPS Receiver
TOMTOM 910 will not turn on after charging
TOMTOM 910 looks like it is charging while in the charge cradle (green power light is on). But, it does not turn on when the power button is pressed. It is passed the 2 year warranty period. Any suggestions? Thanks in advance!
Don Same problem, charged it last night ..this morning nothing. top left green light only comes on when you plug it in to the ac socket but will not turn on. about 2.5 yrs old, used under 30 times.
    Brigadier General:
  • 6,966 Answers
Initially, have you tried pushing the button at the back to reset the device, near the dock connector. You would needs a very thin paperclip that should fit through the plastic hole to reach the button underbeneath.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 22, 2008
  • 10,515 Answers
Reset ur tomtom 910 .
The procedure wld be :-
1) Press and HOLD power button
2) While holding power button, press in RESET button
3) While still holding power button, release RESET button
4) Continue holding power button, you should see TomTom reboot...........
If tht wld solve, perfect, unless buzz me :)
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to check the batteries
or replaced if it is bad!!!
    Genius:
  • 1,550 Answers
I was thinking that may be a loose contact.
The loss of the rubber grommet located at the back of the unit.
That causes the unit to lose contact wtih the charger.
  • SAM ANDERSON Nov 22, 2008
    I am thinking that may be a loose contact.
    That causes
    the unit to lose contact with the charger.
Wil not turn on
Put the receiver in the charging cradle. Does the green charging light appear? If it does not, you might just have a defective cradle and hence a completely flat battery; try charging with the car charger and retry. If it doesn't charge with either charger, the power section of the TomTom is obviously gone.
Assuming you now have a charged TomTom, keep the power button pressed for five seconds. If it does not turn on, try resetting it by inserting a paper clip in the RESET hole hidden below the front cover.
If it still does not turn on, it's either a defective power button or a faulty mainboard, and I'm afraid you can't easily fix either; you'll have to send it to maintenance.
Let me know how it goes...
Mar 15, 2010 | Tomtom GO 910 GPS Receiver
TomTom GO 910 won't turn on.
Two possibilities:
- if someone has used the wrong charger, and connected it to a 12V supply, the mainboard may be damaged. In that case, you need a replacement.
- the battery may be discharged. Even if the green light is on, it doesn't necessarily charge up. Try pushing it hard onto the mount for a few minutes, then see if it will turn on.
Feb 08, 2010 | Tomtom GO 910
Hi my tomtom 910 go wont switch on ], but when useing the charger the little green light lights up and will stil not switch on ive tries the hard resetting and does not work
I've had a similar problem on 2 TomTom 910s.
First, try holding in the reset button while holding the power switch down for 5 seconds.
If that doesn't work, let it charge for 12 hours and while it's still charging, hold the power switch down for 5 seconds.
It worked for me on both
Good luck
Jun 07, 2009 | Tomtom GO 910 GPS Receiver
Blank screen but green light is on
I have had this on my 910, It turns out that the motherboard needs replacing and after looking on here its quite common.
Its quite esay to replace and perhaps worth changing the battery whilst your in there as well.
Google for instructions or flick through this site.
Apr 15, 2009 | Tomtom GO 910
According to Kevin A who says, and thanks by the way (There is a reset button on the back at the top of the unit. It should be on the right side as you turn the unit around. Insert a paperclip or pin into this hole, and the unit should reset) at it works 100% because I tried this morning after being quoted £55 to have my GO910 fixed and now it works after the price of a paper clip. Doug rrp3
Nov 21, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910 sat nav.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Mar 25, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910.
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
78 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
