Question about Microwave Ovens
Shart Microwave model R-1514 fails to start. Beep is heard when start button touched but internal fan or microwave does not start. All other buttons such as fan, light ect work.
  • Microwave Ovens Master
  • 9,098 Answers
Your bottom door switch or its mount is bad.
We have the R1500 series service manual and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type from us for $5 postpaid.
Posted on Nov 25, 2008
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Start microwave clockon sharp carousel oven
Not sure what the question is.. But if it is how to start the clock in a COUNT DOWN mode, then:
1, Touch TIMER BUTTON
2. Program in the length of time you want to use, before alarm comes on
3. Hit start button.
Unit will beep at the end the count down.
Kindly,
Jim
Dec 10, 2009 | Panasonic Microwave Ovens
Sharp R 1514 fan button
The only two springs I know of in this model are for the door open button and the door latch.
We have a similar model's service / repair manual and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly and troubleshooting tips.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
If you have a bad fan button, you would need to order a new select button assembly.
The part number is JBTN-B138MRF0 and you can order it here.
If you need other parts for this model, you confirm part numbers and order them from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 24, 2009 | Sharp R-1514 Microwave Oven
I have a sharp microwave oven R 1514. there are 4 buttons on the front and one is broken, will not pop back out. I bought new springs and need help with the installation
It looks like you need to remove the unit from the wall, remove the outer cabinet sheet metal, then remove about 6 screws from the backside of the control panel.
You should be able to tell as you get in there what needs to be removed.
But it doesn't look like you can access to replace without taking the outer cabinet off.
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
Microwave
chek the wire of the internal start button & also checked formthe fuses/ all check the button is woking propely/
Nov 19, 2007 | Daewoo KOG-867T Microwave Oven
It's displaying "lock" and The keypad is not responding.
1. Touch the "CANCEL" pad. 2. Touch and hold the "0" (zero) pad until the word "LOCK" disappears from the display and a single beep is heard. The microwave is locked the same way. You can download a manual similar to your model here: http://tinyurl.com/vpxss
Nov 03, 2006 | Tappan TMT104E1 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
