Question about Microsoft Computers & Internet
Excel Addition How to add on Excel?
  • dr_ifoley Nov 22, 2008
    Have asked for assistance since I don't know how to use Excel and just wish to add a total
  • 45 Answers
You may add typed-in values (numbers only) or numbers found in cells.
always start your equation with = then separate values with +
Posted on Nov 25, 2008
How to repair damage excel file
Use Excel Repair Toolbox designed to restore data from corrupted .XLS files. MS Office .XLS file repair software can fix many error.
For more: https://www.xlsrepairtoolbox.com/
Jul 14, 2015 | Microsoft Excel for PC
How can I convert quattro pro files qpw to work in excel?
put the same question in your excel help and you will have your answer
Aug 22, 2014 | ASUSTeK COMPUTER Asus Taichi21 Notebook...
What did I do, excel is frozen, can not scroll up?
It might be as simple as Frozen Panes.
Go Window / Unfreeze Panes and see whether that fixes your problem for you.
Apr 26, 2014 | Microsoft Excel for PC
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
What is excel
Microsoft Excel is a commercial spreadsheet application . It features calculation, graphing tools, pivot tables, and a macro programming language called Visual Basic for Applications.
Microsoft Excel has the basic features of all spreadsheets, using a grid of cells arranged in numbered rows and letter-named columns to organize data manipulations like arithmetic operations. It has a battery of supplied functions to answer statistical, engineering and financial needs. In addition, it can display data as line graphs, histograms and charts, and with a very limited three-dimensional graphical display.
Regards,
Shrey
Jun 04, 2011 | Microsoft Excel for PC
Or download the microsoft excel to my comp.
http://download.cnet.com/microsoft-office-compatibility-pack/3000-18483_4-10648733.htm
By installing the Compatibility Pack in addition to Microsoft Office 2000, Office XP, or Office 2003, you will be able open, edit, and save files using the file formats new to Word, Excel, and PowerPoint 2007. The Compatibility Pack can also be used in conjunction with the Microsoft Office Word Viewer 2003, Excel Viewer 2003, and PowerPoint Viewer 2003 to view files saved in these new formats.
excel and word from download .com free
hope this helps
Apr 03, 2011 | Computers & Internet
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
PROBLEM WITH EXCEL
  1. Click the Microsoft Office Button default.aspx?assetid=za100771021033, click Excel Options, and then click Add-Ins.
    1. View the add-ins and application extensions that are categorized as follows:
    2. Active Application Add-ins Lists the extensions that are registered and currently running in your Office program.
    • Inactive Application Add-ins Lists the add-ins that are present on your computer but are not currently loaded. For example, smart tags or XML Schemas are active only when the document that references them is open. Another example is the COM add-ins that are listed in the COM Add-ins dialog box. If the check box for a COM add-in is selected, the add-in is active. If the check box for a COM add-in is cleared, the add-in is inactive. To learn how to open the COM Add-in dialog box, see the section called Turn off or manage the installed add-ins.
    • Document Related Add-ins Lists template files that are referenced by currently open documents.
    • Disabled Application Add-ins Lists add-ins that were automatically disabled because they are causing Office programs to crash.
  • Mar 28, 2009 | Microsoft Windows XP Professional
    Computer
    Any formula in Excel starts with the equals sign ("="). This is how Excel distinguishes between formulas and literal values. Knowing this, you can create lots of formulas using the usual operators of +, -, * and / for addition, subtraction, multiplication and division, respectively. Please see the examples below.
    Add 1 + 1: =1+1
    Add the contents of cell A1 to the contents of cell B1: =A1+B1
    Subtract 2 - 1: =2-1
    Add the contents of cell A1 from the contents of cell B1: =B1-A1
    Multiply 1 times 2: =1*2
    Multiply the contents of cell A1 times the contents of cell B1: =A1*B1
    I hope this resolves the question. If not, please let me know.
    Aug 08, 2008 | Microsoft Computers & Internet
    Excel password is protected....... but not i don't know that password,,,,,,, so password are remove if i see that password
    Excel Password Remover 2008
    Instructions
    FAQ
    Disclaimer
    Excel Password Remover PRO
    Recommended links:
    Password recovery software (Word, Excel, Outlook, Exchange, Visual Basic modules, Access, Winzip, Lotus 1-2-3, Lotus Organizer, Lotus Wordpro, Backup, Project, FileMaker, Schedule+, Money, Paradox, Act!, Mail, Windows NT)
    Instant password recovery (Instant online recovery service for password protected MS Word and Excel files. Free online preview of encrypted file content. )
    Visual Basic Password (Instant recovery of VBA-passwords in Office programs)
    Excel add-in decompiler (Converts Excel add-ins into normal workbooks)
    Have you ever forgotten your Excel workbook or sheet password?
    Here you can download a FREE Excel add-in that removes/cracks sheet and workbook password protection in Excel®.
    NB! This program can't remove file protection, i.e. if you are unable to open the file, this program won't help you. You could try Excel Key to remove file protection. If you need to crack the VBA-password try this one.
    This Excel add-in (password.xla) works fine in Excel 5.0 and above (including Excel 2000, XP and 2003).
    This program will remove passwords of any length, also passwords containing special characters.
    Download here: password
    Feb 23, 2008 | Computers & Internet
    Computers & Internet Logo
    50 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
