When turning the oven on it makes a terible noise while cooking and half way through cooking things the oven shuts down the elements shut down the oven lights turn off however the timer and clock remain on. and after about 1/2- an hour to 1 hour the oven restarts this is very fustrating and i dont know wheather to fix it or replace it, it is only about 5 years old
  • Anonymous Mar 23, 2014
    when on cook or microwave mode it s making a grinding/grating noise which is getting worse and also continues until the oven has cooled.
  • Washing Mach... Master
  • 3,463 Answers
Sounds like you could have a faulty fan motor, assuming it is a fan assisted oven
Posted on Nov 22, 2008
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
I have a lamona hja3400 oven and the element has stopped working. I'm trying to get the element out but it seems to be fastened on the back of the oven not inside it as with other types of ovens. Does...
hi my lamona oven started to make a noise like a pinging noise it was working the noise would come and go it would get worse half way through cooking. but last night the noise seemed to have lasted longer and the oven knocked itself off any ideas what the problem could be.
Aug 30, 2013 | Ovens
Kenmore stove model# 665.92024100 While cooking
Check and see if the broil element has shorted to ground.
Apr 13, 2010 | Kenmore Ovens
Oven shuts down in middle of cooking
What is the make and model of your cooker?.
I do not know the answer at this stage, more information would help.
Nov 23, 2008 | Ovens
I'm only guessing here but it's possible the internal thermostat is broken and the oven is overheating {?} and triggering some built in safety switch that turns the oven off so it won't cause any damage.
I suggest you call the company, or a local oven repair person.
Letting us know if it is Gas or Electric may help too.
Aug 01, 2017 | Ariston Technologies AWD 121
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
it really doesnt matter because the heat transfers directly onto the food therefore you can leave the door open or shut.
Jan 05, 2008 | Equipex PZ-330 Electric Single Oven
Oven not heating
there is more to this than meets the eye if youre oven takes a long time on fan setting it may be thermostat but more likely to be fan not turning at all or quickly enough the stat capillary is above oven element and if fan not blowing air away from capillary oven stat will shut oven temp down too soon if using conventional heat eg no fan make sure there are no full size trays directly on bottom of oven this will block heat from bottom element effectively giving only half the heat output.
hope this helps
Jun 13, 2007 | Bosch HBN 430560B / 430520B Single Oven
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
