Question about Canon EOS Rebel GII with 35-80 lens 35mm Film Camera
Why is my camera not working?
When I press the shutter button my camera makes a wierd winding noise for 5 seconds then the battery icon flashes. I have replaced the batteries and the icon indicates a full battery prior to pressing the shutter button when I am tryin to take a picture. I have a cannon rebel eos GII Alisha
SOURCE:
  • 36 Answers
SOURCE: canon eos rebel t2 battery indicator
guido462:
new batteries - brand new? fully charged per spec?
Posted on Jan 25, 2008
cammedic
  • 667 Answers
SOURCE: shutter speed and apiture priority
The green rectangle is full automatic. You can use the P mode for the same function. In the P mode, you can change settings, in the green rectangle, you cannot.
Posted on Feb 14, 2008
SOURCE: low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
Posted on May 13, 2008
  • 4 Answers
SOURCE: Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
(http://photonotes.org/articles/oily-shutter/).
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
Posted on May 22, 2008
spotatohead
  • 95 Answers
SOURCE: My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Posted on Nov 29, 2008
Why does shutter error message appear when button pressed?
If the shutter has 100K operations then the camera may be due for a replacement (not worth repairing).
Please make sure you have a fully changed battery in the camera. If the camera does not have a battery icon anywhere showing a low or dead battery then you have a camera that should be sent to a Nikon Authorized service center. They can clean and repair your camera. They will; QUOTE the repair before you pay. All you are out is shipping costs.
Aug 06, 2015 | Nikon D90 Digital Camera
Mi camera digital Nikon D 60 got a messaje: ERROR PRESS SHUTTER RELEASE BUTTON AGAIN Cant anyvary help me to fix it
It is nothing to lose to try this:
1. Remove the battery (the charged and good working battery),
2. Switch the power to ON position,
3. Press the shutter button for 5 seconds.
4. Switch the power to OFF position,
5. Insert the battery,
6. Switch the power to ON position,
7. Try to take a picture.
Please post the result here.
Mar 03, 2014 | Cameras
I don't know how take a picture?
It's actually a lot easier than you'd think. You don't tell us what kind of camera you've got, but here are some general tips for beginners:
1. make sure the camera has charged batteries in it, and a memory card.
2. find the power button. It's probably on top, near the shutter "take a picture" button. Press and hold it until the camera comes on. It should show you the current 'view' on the screen.
3. If there's a selector dial on the top... turn it to the green one; that's 'easy shooting'.
4. fully press (squeeze) the button. Most kids who moan that 'it didn't take' it's because they only half pressed it. When it takes, the display will show the picture for a few seconds, before going back to the live view.
5. to see your picture, find a button that has the little triangle icon pointing right, like a 'play' button.
6. to go back to taking pictures, press the shutter button again
7. to turn it off, press the power button until it turns off
If that doesn't work for you, tell us what kind of camera you have. That'll make it easier (just a bit!)
Mar 26, 2011 | Cameras
Camera will not take pictures and I can not see anything thru
Found this on another web site. Worked for me
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority (“Tv”).
Use the four-way button on the back to set the shutter speed to 15 seconds.
Press the shutter release. Count to seven, then pop open the battery compartment. (I discovered that the camera will beep when you do this.)
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
May 13, 2010 | Canon PowerShot S2 IS Digital Camera
Shutter won't click, Films Winds back in canister.
Yes.
Shutter motor is bad and needs replacement.
Apr 01, 2009 | Pentax MZ-M 35mm SLR Camera
Shutter sticks
Does the light flash for 10 seconds, with a series of beeps getting faster before the picture is taken so you miss the shot, or are you saying the shutter stays open for several seconds giving you a whiteout picture?
If the former, then the self-timer is on. Press the button on the back of the camera to the right of the displays just under the AV button. The display icon will change from :-
Hand sweeping round clock = self timer mode
Simple square = single shot mode
Stacked squares = multi shot (keep finger pressed to keep shooting)
Feb 13, 2009 | Canon Digital Rebel / EOS-300D Digital...
The flash on my camera is not working!!!!
If the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Hope this one helps.
Jan 12, 2008 | Samsung Digimax S630 Digital Camera
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
Dec 13, 2007 | Samsung Digimax S630 Digital Camera
Using flash freezes up camera
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Canon EOS Rebel GII with 35-80 lens 35mm Film Camera Logo
180 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
