Question about Kenwood VR-7070 Receiver
Reciever moves to default setting on its own
In video 1, 2, 3.. after an undetermined amount of time the receiver goes back to what seems to be the default setting of cd/dvd. Also when I am playing multiple cd's on video 1, when the first cd or when in ramdum mode the first song is over the receiver switches back to cd/dvd. Then I have to go to the remote and change back to video 1 and do it all over again. Video 1 is my cd player Kenwood #CD-404 Video 2 is the vcr Video 3 is the television CD/DVD is the dvd player Thanks, Jim
2 Suggested Answers
robotek
  • 1512 Answers
SOURCE: kenwood 606 receiver
disconnecting the tv from the audio connections on your amp may have created a powersurge in the audio input selector IC. Try powering down the amp at the wall completely for 5 mins and turn it on again. Check to see if operation has returned. If not then it may need an audio selector chip replaced.
This problem can be caused when connecting or disconnecting rca connectors from non earthed equipment like TV and VCRs, By the nature of this type of connector, it will spike the input line by connecting with voltages floating often over 100volts.
to avert this problem occurring, wire all the equipment up and with aerial disconnected and tv / vcr turned off at the wall socket. Turn the equipment power on at the wall last thing.
Posted on Dec 15, 2007
Why dose recording in dvr goes on default date when light goes
Well, I'm trying to decipher this. Why does the recording in DVR revert to the default (date/time???) when the light goes off and comes back on.
I'm guessing you are trying to say time, not date, maybe day?
The DVR is trying to remember when a show comes on and record it, based on your settings. Usually shows come on at a specific time. DVRs usually update their scheduled recordings based on updated programming guide information. If you are constantly unplugging or causing your receiver to otherwise restart, most receivers will download an updated guide upon getting power back or restarting (DVRs themselves not having any idea how long they've been without power, download a new guide just in case after you unplugged them you moved to Arizona). During this time, the recording you set is showing the original time you set it up, because until the guide is downloaded, it has no idea that its wrong.
My best advice, even if I'm wrong about our language barrier here, stop unplugging your receiver. Leave it plugged in and powered at all times.
All times.
For ever.
Dec 18, 2016 | Televison & Video
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
Nov 19, 2015 | Kenwood VR-606 Receiver
How do i reset my pioneer vsx 919 ah amp reciever back to its original settings
In the manual, page 72
Resetting the system
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
1 Switch the receiver into standby.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
The display shows RESET? OK.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
Feb 01, 2011 | Pioneer VSX-919AH-K A/V Receiver
Hi I just set up Samsung SWA-4000 and for some reason I cant get it to link up it says Rear Check on the receiver and then the module goes to stand by
This means that its lost the connection to the wireless transmitter, the error means Rear CHK or check hence RCHK. Seems that if the unit is not quite in line of sight the connection can be flaky. I would check the positioning of the reciever. Try moving it, see if you cant get a better connection.
May 18, 2010 | Samsung SWA-4000
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
Reciever shuts off
Hi there
May I ask how many watts can your reciever handle ? And how many watts does your speakers need in order to be powered up (input). The two speakers you have installed might be too powerful for your reciever to handle. You might have to down grade to less powered speakers. All in all you have an excellent product there good choice...
May 11, 2009 | Onkyo HTR500 Receiver
Reciever get louder in one channel then static then goes back to normal
HAI,IT'S A SMALL PROBLEM ANY DRY SOLD INLEFT AUDIO SECTION
Apr 30, 2008 | Nakamichi AV-10 Receiver
Kenwood VR-7070 Receiver Logo
41 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
