Question about Polaroid TTM-2401 TV
Interferance on tv
I'm experiancing interferance after the tv is warmed up 10 min or so. tried new cable.. new outlets power surges.. its the only tv in house this does it to. turned off router. Its like someone running a microwave. I bought in Jan and didn't mess w/ it till now. Its unwatchable when this happens. I unhooked cable and ran game system through it and did the same thing. I read bad reviews on this tv. Ive tried buying rhi chokes still now help. Any other ideas?
    Genius:
  • Polaroid Master
  • 1,689 Answers
What is happening on this set, like others (not necessarily this make and model), is sometimes there are decoupler capacitors in the power supply and the secondary voltage supply from the flyback area that start to go opened in value. This allows some high frequency ripple to get back in to the video processing and CRT drive circuits. You will visualy see this as waves or interference in the picture no matter what you do. The solution is to have the set properly serviced.
You will not be able to fix this set yourself. Proper troubleshooting is required to find and replace the defective parts. There are high voltages in many of the areas where this fault can be occuring. I would suggest to take the set to an experienced service tech to properly fix the fault. Most of the cost will be the labour to do the work.
Considering that this is not a high quality set, you are probably better off to get a new set. I would suggest to stay with the big brand names. You will pay more, but you will get better value and performance for the money spent.
Jerry G.
Posted on Apr 12, 2008
My Panasonic TV/DVD/VCR Combination has a dull buzz sound on all channels. How can I stop that Dull Buzz? Model number PV-DM2719. LBV
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 17, 2011 | Panasonic Televison & Video
Why does my t.v. automatically shut off after 15 seconds?
Jan 16, 2011 | Sylvania SRCD227 27 in. TV/DVD Combo
I must have pressed something wrong because I used to be able to record Programs 1,2,3,4,5, and now it will not record and brings up 1,2,4,7,8,AV1, AV2, AV3. I have spent the last hour trying to make...
Jan 15, 2011 | Televison & Video
No color
Jan 15, 2011 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
The tv will not come on...when you hit the power button a red light flashes . but nothing comes on
Jan 15, 2011 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
No sound output need sound unit
Jan 14, 2011 | Mintek DTV-233 23 in. TV/DVD Combo
How can i exit from service menu code,picture is blinking and there is no sound.Service menu is appearing when set is power on. set is 14''philips vardaan . please shortout my problem.
Jan 13, 2011 | Philips 20DV6942 20 in. TV/DVD Combo
Tengo un tv de 14 pulgadas marca symphonic modelo sc3913 donde consigo un control ó que control me sirve para poder entrar al menu
Jan 12, 2011 | Symphonic SC3913 13 in. Combo
How can i fix color broplem of the television?
Jan 12, 2011 | Aiwa VX-T1470 14 in. TV/VCR Combo
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Polaroid TTM-2401 TV Logo
32 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
