Question about Weather King 12AJA4801AH Air Conditioner
WeatherKing Acclaim II
We changed from propane to natural gas, changed the jets and the system short cycles and doesn't blow hot air
  • 4hammys Dec 22, 2008
    My Weatherking Acclaim II seems to hit or miss, it cycles short sometimes blows cool air and often will allow the temp get to 60 degrees. The setting is constant at 69 and no one is screwing with the thermostat, so we don't know what the problem is. We can hear it come on then just go off after a few mins. When we decide we have had enough we come on down turn it off and then back on and then it decides to work and heat up the house. Anyone know what is wrong with this furnace? Any ideas?
  • 182 Answers
Not only the jets but you need to change the spring in the gas valve and cut the pressure WAY back to prolly 3.5"wc
Posted on Nov 23, 2008
Need to know what parts I need to convert a Montgomery Wards 700 heating unit from gas to propane?
gas and propane are the same fuel
what you are really asking is the jets to change from natural to propane (LPG)
get in a gas fitter to do the job as they have the training and the jets to do the job and knows how to adjust the air shroud to get the correct burn
gas is not in the diy domain
Sep 05, 2017 | Heating & Cooling
Can i convert a garland mod g286 stove from natural gas by installing apropane regulator
no
the modification from natural to propane or from propane to natural gas requires a jet change for all burners and an air flow shroud position change to get the correct blue flame ( correct air /fuel ratio)
it is a job for a gas fitter who will have the correct jets for each burner and will know how to adjust the shrouds
Jul 12, 2016 | Garland Kitchen Ranges
Maytag range Natural gas jets to Propane jets
it is a simple replacement but the problem is properly adjusting the air shrouds to get the right air/ gas mixture to burn correctly
lpg jets are available from a gas supply shop and because of the dangerous nature of gas , I would suggest that you have an accredited gas fitter do the conversion
Nov 25, 2015 | Maytag MGR8674AS
How do I change my ge monagram grill from natural gas to propane?
change the jets propane jets are a little larger then natural gas
Sep 04, 2011 | GE Kitchen Appliances - Others
I have a Whirlpool gas dryer. I have gone from a natural gas hook-up to propane. Is there anything I need to do different for that natural gas installation?
You will need to change the gas discharge jets on the burner so that the burner gets the proper mixture of gas and air. Propane accessory stores should be able to furnish a conversion kit.
Aug 21, 2009 | Dryers
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
  1. The sensor that tells the furnace whether the gas is lit has got build-up on it and is giving the furnace bad information.
  2. The flame sensor is often a single wire or rod that sticks up in the center of the flame.
  3. You can shut off the furnace and the gas and clean the sensor with some sandpaper.
If that still doesn't work, the sensor may need to be replaced.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Where can I find weatherking acclaim II filters
Your best option is to contact your nearest wheather king/Rheem dealer. They may have replacements. The filter store online, they offer any size and cheap too!
Nov 30, 2008 | Weather King 12AJA4801AH Air Conditioner
Finding the cooling contactor on weatherking acclaim II gas furna
the "y" terminal sends the hot leg of the 24 volts and the "c" terminal sends the common leg to the condenser..
Nov 15, 2008 | Weather King Heating & Cooling
I want to be prepared to change my Carrier Furnace from Natural Gas to Propane if I need to.. I was told that their should be a little sack with a replacement jet hanging there somewhere. There is not.. ...
not only do you need the nozzles....you will need the spring changed in the gas valve and a manometer to set the proper gas pressure output from the valve.If you change the jets only you could do alot of damage to your furnace.
Sep 23, 2008 | Carrier Heating & Cooling
Weather King 12AJA4801AH Air Conditioner Logo
161 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
