Question about Goodman GMS90703BXA Heater
Carrier 58GS150-CB ignites but fan will not blow (Loud Buzzing)
My 20 y/o Carrier fires up no problem. My problem is when the fan kicks in there is just a loud buzzing noise. The buzzing lasts for 30 seconds or so and buzzing stops. 5 minutes later again will again start buzzing. If I put thermostat in Fan position the buzzing is constant.
Please Help its 24F here in Ohio
Frank & Family
  • k2marketing2 Nov 22, 2008
    After removing fan assembly service panel all looked very clean except there was what looked to me to be a large amount of dust inside fan motor. I was able to turn squirrel cage with no resistance. Any suggestions? Also took out four fan assembly screws, removed fan speed wire, and power wires. Any trick of trade to pull this bad boy out.. or to oil motor without doing so? ( rear panel is not accessible)
    I let furnace cycle with service panel switch pressed closed with duct tape. I definitely could see motor attempt to turn squirrel cages but to no avail. Shut down power to furnace and will begin removal of fan motor. CHALLENGE: removing vent housings! unlocked set screews and marked position of screw to shaft for reinstall but cant get them removed. Was told not to use a hammer, any suggestions.
  • 3 Answers
The loud buzzing soud i found to be the fan blower motor. I removed the fan bracket assembly and sprayed a little WD-40 on the set screws and protruding shaft so that sqirrel cages could be removed. (Also marked position of set screws on shaft) once squirrel cages were removed I removed 4 motor mounting bolts. Cleaned sqirrel cages and housings with industrial strenghth rim cleaner to remove solid dirt and will replace motor and capacitor.
BTW thanks for nothing
Posted on Nov 23, 2008
My 93 taurus turns over but no start the CCRM buzzes when the key is on and I have constant power to the coil wire when not cranking changed CCRM no help used too if I hit CCRM it would stop buzzing
Ignition control module or PCM problem or pick up coil ! The CCRM - constant control relay module just has control relays for the fuel pump , cooling fans , A/C clutch coil control , PCM power . Nothing that would make the coil fire continuosly . I would check out videos on youtube test ford ignition system's ScannerDanner gets his but kicked by an 88 150 EEC IV Ignition
Dec 12, 2016 | 1993 Ford Taurus
Carrier heat pump loud hum even when turned off
Look down into the unit through the fan frill. Is the large pipe from the compressor frozen over?
Aug 04, 2016 | Carrier Heating & Cooling
Thermostate kicks pump motor on ok. but when its time for the fan motor, all you here is a loud humming then the breaker blows
check for a failed start/run capacitor for the motor
if the motor spins freely then the humming will be a frequency hum because there is not enough power to start the fan running
the extra current will blow a cb
Apr 08, 2016 | Mastercool 67680 Evaporative Cooler Air...
I have an older Carrier furnace type 58ss. The main burner will not ignite. Operating look ~ thermostat set @ 78 deg, switch furnace on, inducer fan running, pilot light clicks and ignites, inducer still...
power to gas valve ok .. Replace gas valve after checking gas valve coil for continuity/resistance... with valve removed ...and power to valve ... try blowing thru valve from supply side ... stuck valve.... replace...
Nov 01, 2013 | Heating & Cooling
Dont know how to start my honda cb 350
First- turn on the gas. wait for it to get to the carb. Next switch on- close the choke, give 1/4 throttle, Kick it - if it's a no start after about 4 kicks - open the choke and give 1/2 throttle and close the gas.(your flooded)- 4 more kicks and check the spark plug for wet fuel or dry. If dry- dip the business of the plug in fuel and try again. Still no start- replace the plug.
If all that fails- you can disconnect the ignition switch and that will separate the wiring from the ignition- be careful here because you can not shut it off with the switch it can be killed with the choke or pull off the ignition wire to the spark plug.
Still no start, do a compression test as it needs at least 80# to fire.
Nov 03, 2011 | 1971 Honda CB 100
I have a Maytag 2651HEW . Seems to be cooling and
Thant must be checked out soon as that buzzing sound is the start relay struggling to start the compressor. The longer it goes on without repair to either the sart/run capacitor, start relay and overload the higher the chance there is for complete compressor failure. The condenser and evaporator areas should be cleaned and inspect both internal freezer fan and lower condenser fan that both run without stopping. Let me look for a service manual for your model and return soon, Thanks, Sea breeze
Jan 10, 2010 | Maytag MSD2651 HE Side by Side...
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Oct 29, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Goodman GMS90703BXA Heater Logo
416 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
