Question about Hotpoint HSM25GFRSA
Hot point side by side electronics not operating damper
Model hsm25gfrasa hot point side by side, refrigerator side not cooling damper wont open to allow air in from freezer, how do I test the damper motor, temperature sensor, temperature control since everything is electronic or ??? Thanks tk
  • 1 owl Apr 02, 2008
    hot point side by side damper door will not open to cool down refrigerator side,the model number is,hss25gfpaww
  • Anonymous Apr 02, 2009
    we have replaced everything we can think to replace from the motherboard, fan motor, solenoid, defrost sensor, damper and thermister set and the thermistor on the freezer side at the bottom and the fridge still won't cool when the damper is plugged into the ceiling. If I unplug the damper then everything works fine except there is too much frost up near the top of the freezer and it freezes the ice maker part that the solenoid runs and it won't give me cubed ice. We are so frustrated that we can't find the thing causing this to not work. We paid a repair man over 350 dollars and he is the one who replaced all of that twice and he can't figure it out either. any help?
  • 237 Answers
See if you have some paperwork on how to test, etc. located in a plastic bag taped up to the underside of the fridge. Pull the front vent cover off and you should see (feel) a bag taped up there with the test paperwork in it. If you don't have it let us know and maybe I can email it to you.
Posted on Dec 26, 2006
Code 4 flashing
You have the electronic Beta control and an electric damper door. Though the Beta control usually fails for other reasons, your most likely failure would be the motorized damper door has stick open, or the motor is dead, there is a strong chance that it is blocked with excess frost preventing it from operating. You can turn the main control off located where the display is and listen for the sound of the damper door operating, wait 15 min or so, and turn the fridge back on and listen for the sound of the motor running in the back top of the fridge, if no sounds either way you damper assembly is a good place to start. Pleazer Appliance...
May 03, 2014 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
My kenmore side by side refergerator is not cooling like it should. My freezer is working fine. The compressor seems to be working but it is hot. My cooling fan is working fine. My thermostats seem to be...
I dont know if you have a newer or old model(thanks for NOT including model# in your question) but if its fairly new their very likely is a damper door in the upper left corner of the fresh food compartment that opens to let air into the FF compartment when it needs it. That damper (if it has one) is not opening.
If that damper is opening..is thier frost build up on back wall of FREEZER? if thier is frost build up its not defrosting automatically ,and that build up frost is blocking air flow into FF section.
Aug 24, 2011 | Refrigerators
I have a kemore coldspot side by side maufacture date 04/07 that is not cooling properly. Freezer gets cold but won't freeze and fridge section gets cool. I have checked condenser fan runs and compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Wont cool
The reason the doors get hot is to defrost its ok.
Jul 26, 2010 | Samsung RS2630SH Side by Side Refrigerator
Freezer working but refridgerator at room temp. Door seal hot.
either the evaporator coil is iced up which means the defrost heater is bad,the defrost control is bad or the damper vent door which throttles cold air in isn't opening fully from the freezer to refrige,the evaporator fan isn't running or if electronically operated the main board behind the unit can be bad on these as this board controls all electrical issues
Jun 20, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
GE side by side Model GSS25JFMD 2 yrs old. Original problem was not staying cold. now I see if I unplug for half hour it seems to work right but sometimes freezes in fridge . I'm hearing a clicking sound...
These problems are saying relay/capacitor replacement and if that don't work then compressor replacement.
First change the relay and the compresssor cap. See if you have improvement...if not then you will need to have the compressor replaced.
Here is a tip about the relay and cap....
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Heatman101
Feb 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MSD2657HES Refrigerator Side by Side
The air that cools the refrigerator section comes from the freezer. The refrigerator temperature control controls the run cycle. You may have to replace or have the thermostat replaced. The temperature control has failed.
Jul 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
Gsh25vgpccc ge side by siderefrigerator
well if you keep that damper open im sure everything in your refrig- will freeze is the temp- in the freezer o.k. if you have an ice maker is it working properly because if your freezer does not maintain the right temp your ice maker wont work. if so you might have a bad temp control (thermostat)
Dec 23, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSM25GFRSA Logo
362 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
