Question about Amana ARB9059CS Bottom Freezer Refrigerator
Whooshing noise from behind water filter in Amana ARB 9059CS
Our refrigerator/freezer makes a low, two second, whooshing sound of water coming in at the intake water line behind the filter in the top of the refrigerator. We used to hear this sound about once every two hours. Now it happens about once every 2 minutes. There are no leaks and no problems with the water dispenser or ice machine. What could be causing this?
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
  • 212 Answers
SOURCE: Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Posted on Jun 21, 2009
SOURCE: I have an amana side by side refrigerator.part #
what was the problem ?
Posted on Aug 23, 2009
woodchuck789
  • 4070 Answers
SOURCE: My Amana AFB2534DEW fridge is leaking onto floor,
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Jan 07, 2010
Testimonial: "Super fast feedback!"
How do I replace a brake booster on a 1998 Buick LeSabre? Brakes hold but make a whooshing when applied.
May not be the booster as some do make a noise when the brakes are applied. To test press the brakes several times with engine off, Press the pedal down hard and start the engine , the pedal should move down slightly and there should be no whooshing sound . if the above is ok so is the booster.
Mar 26, 2015 | 1998 Buick LeSabre
Whooshing
It will sound like a waterfall, this means your system has lost its refrigerant gas due to a split pipe somewhere in the system
Apr 10, 2014 | Refrigerators
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Nov 16, 2013 | Samsung RF265AA Bottom Freezer French Door...
My Samsung refrigerator makes a funny whooshing sound.
Try removing the ice tray and look for cubes jammed between the ice maker and the wall. After I cleared them out the whooshing stopped immediately.
Feb 01, 2011 | Samsung RF265AA Bottom Freezer French Door...
2002 Ford Escape whooshing noise when accelerating
Sounds like the fan clutchis driving the fan all the time, and therefore at a higher speed than it used to.
Jun 15, 2010 | 2002 Ford Escape
Loud whooshing sound on acceleration. Came on instantly.
1st Any recent work done on vehicle? Air filter attached properly, filter element in correctly, hose clamps on air induction tight?
2nd Stand behind vehicle while it is running. Have someone slowly step on the gas pedal. Does the 'whooshing' sound seem to come from the exhaust pipe(s) when giving it gas? If yes, the catalytic converter pasrt of the exhaust system) may have partially collapsed inside (due to rust), and is partially blocking the exit of the exhaust gases. To fix this, you will need to replace the converter. If this is the case, check online for a new aftermarket unit, as they can be very expensive.
Mar 20, 2010 | 2003 GMC Envoy
Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
Good day,
If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
Dec 21, 2009 | Refrigerators
No soud just a 'whooshing' noise...
Make sure that you have second audio program turn off.
Nov 23, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Refrigerator whooshing sound
since new compressor installation that noise is either a little to much gas in the system or to little. Mostly in my experiance, to much. Need to get Tech. back and check gas level. quick to see whats happening internally then.
Sep 16, 2009 | Refrigerators
Amana ARB9059CS Bottom Freezer Refrigerator Logo
81 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
