Question about Sewing Machines
Cleaning and maintenance
Love the machine, Using it for making curtains and quilting. Having put some time in on the machine thought I should clean it...
Followed manuals instructions. Machine is now somewhat noisy.
Troubleshooting suggests inferior oil...I didn't oil it as there is no mention of oiling in the manual.
What type of oil and where should I oil the Shark Intelli-sew 9110?
It seems to be a closed system.
    New Friend:
Bstowle, I just came across your post about oiling your Intelli-Sew 9110. I have the same question as I am wondering if the problem I am having is due to needing oil. The link apolonya posted saying this model does not need oil is for a Brother, not a Shark. Did you ever find the correct answer to this question?
Posted on Jun 14, 2013
  • Cari Beach Jun 14, 2013
    I just got a Shark Intelli-Sew Euro-Pro 9110 used (second hand but never used) from someone. I just looked at your link but that is for a Brother...not a Shark.
The hand wheel has become so stiff it wont sew....however, when I put it in bobbin loading position, its normal. Any thoughts?
If your machine was serviced a year ago and you use it extensively, it is probably due for another service. Recommendations are once a year.
Consult your owner's manual. Sounds like it probably needs cleaning and oiling, especially since you said you use it a lot. They do need some periodic TLC to keep them operating well. Mechanical machines, especially, do need maintenance. (You wouldn't run your car without oil.) The fact that the motor is straining but things are not moving is a good indication that it needs some attention. Do NOT run the motor if the machine is frozen--you could burn up the motor or cause other damage!
Sep 27, 2016 | Singer CG-590 Commercial Grade Sewing...
It just started making a knocking sound when sewing but is still sewing good. What could it be.
I suspect that the needle /hook timing could be out and the hook is hitting on the needle or the needle is hitting on the bobbin case
could be a bent needle
Nov 16, 2015 | Sewing Machines
When in darning position, I get large loops on bottom of quilt during darning/free motion quilting.
with some machines the type of spool you use for the thread matters. try different spools.
Jan 25, 2015 | PfaFF Sewing Machines
I am having problems with my Juki TL98E skipping stitches when I free-motion quilt. I have cleaned it well, put in a new needle but still having problems. When I stitch forward, it's ok, but when I try to...
It is a timing issue. I have a TL98E. The needle bends a bit when free motion quilting, moving the needle away from the hook, thus missing the thread. Try to put in a larger needle, or have the timing changed so that the hook "kisses" the size needle that you want to use. Tammy
Nov 18, 2010 | Juki TL-98Q
My Memory Craft sews great until I start to quilt or use one of the different stitches and then the stitches either skip or become so tiney I can't pick them out.
Skipping could indicate you need to use a larger size needle.
Tiny stitches could be save reason, or the top thread is hanging up.
Sometimes the thread can wrap around the spool pin or catch on a rough surface on the end of the spool.
Be sure to use the correct size spool cap and if the thread is wrapping around the pin, a thread net can help.
Give the machine a cleaning according to the maintenance section of the manual for your machine, including cleaning the feed dogs, bobbin case, shuttle and surrounding area.
Make sure the feed dogs are up unless you are free motion quilting and the presser foot down.
This may seem elementary.........just trying to cover all the bases.
May 02, 2010 | Janome Memory Craft 9000 Computerized...
I'm trying to use the Janome 1600P DBX for quilting. A repair tech. went through the machine and cleaned, oiled and set the tensions. It looks like the tensions are set right but the thread breaks after...
I would try this -
Make sure you are not using quilting thread for hand stitching.
Thread the machine with the presser foot up.
If the machine is stitching seams without a problem and the breakage happens with thicker fabrics, it could be the presser foot is not down below where it is closing the tension to the setting of choice.
When the presser foot is up, the tension control opens. When the presser foot is down, the tension control closes to the setting you have chosen.
If this continues, call the dealer/tech and tell them the problem you are having.
Mar 06, 2010 | Sewing Machines
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Thread breaking
I HAVE THE SAME PROBLEM WITH THREAD BREAKING. HAVE TRIED EVERYTHING. FINALLY I GOT SOME UPHOLSTERY THREAD AND IT SEAMS TO WORK MUCH BETTER. NOW i AM HAVING TROUBLE FINDING THE NEEDLES FOR THIS MACHINE. NOT HAPPY WITH MACHINE AT ALL
Dec 09, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
266 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
