Unableto print via laptop using USB chord
The printer not responding to the print command
    Problem Solver:
  • 5 Answers
You tried to print with blocnotes.
Besides the printer came with some software, this software came with an option to print a testpage.
Please explain first what and how you tried.
Is the printer new and never print before.
Is the installation done correctly.
Greetings
Posted on Nov 24, 2008
Printer doesn't respond via USB only WiFi
As my helper partner states, I quite agree but I would also use a different USB which the one you're using might be damaged, use another USB station cause maybe its also damaged. But if it states that the printer is offline...it will never print because its not selected as your active Printer. Actually you are sending the printing jobs to that printer wich is not active or recognized.
Apr 06, 2014 | Office Equipment & Supplies
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
Sep 20, 2011 | Epson Passbook PLQ-20 Matrix Printer
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
My Canon Pixma IP 2200 Inkjet Photo Printer won't respond to any printing commands. It is installed in my programmes. I have tried troubleshooting re setting but it still won't work.
Bottom right of your computer screen where your speaker icon would be? Is there a printer icon?
Printers will buffer (collect) till they can be printed. even if you shut down your computer and restart, these buffered print ques may not leave - printer traffic stops on this first print in the Que.
Right mouse click this printer icon and open all active printers. if there is more then one in this buffer, then select all of these and cancel them..
If this doesn't help and your USB and power cables are connected then unplug your USB cable and wait about 10 seconds and then reinsert your usb cable - see if your computer responds by indicating your printer has been identified. And try printing then.
Best photo printing and general use printing. Canon
Thank you for your Visit to fixya.com
Nov 15, 2010 | Canon PIXMA iP2200 InkJet Photo Printer
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Printer not responding
Try the HP500Hpgl2 driver, it will work with a USB port.
Dec 13, 2008 | HP DesignJet 450c InkJet Printer
Rear NIC Light blinking
I found one of these printers in a parts bin and it looked like it was in great condition so I said what the heck, I'll try it out. Had the blinking light problem and figured it was a nic card because all functions via USB worked fine. If I plugged in a network cable, it froze up all functions except the LCD menu.
Took off the side panel and low and behold, it had taken a bad fall and the NIC card's connector to the main borad was busted. The main borad was fine though so it does everything fine via USB. Its a modulear NIC card so replacing it would probably work, but the chance of finding a replacement NIC card for the printer? Slim to none, it doesnt even have a model number. Only if I come across another one of these printers. Oh well, sweet printer for free, even if it only works via USB.
Apr 29, 2008 | Dell 1600n All-In-One Laser Printer
Printer slow to respond to print command
I had this issue also. Found it to be a firewall issue.
Norton Internet Security, Vista Home Premium.
I ended up having to create a rule to allow inbound TCP from the laptop on port 135. Fixed it.
ps. Be careful setting up such a rule. Several worms make use of exploits on this port. I was very careful only to allow the laptop to loopback to itself.
Nov 14, 2007 | Canon LASER SHOT LBP-2900 Printer
Deskjet 940C slow to respond to print commands
first if you are using the printer conector istead of USB cable that is one reason the second one is the setings for your printer you can go to the printer properties click on advance check to start printing imediatelly and thats it
Nov 07, 2007 | HP DeskJet 940c InkJet Printer
Computers & Internet Logo
59 people viewed this question
Alun Cox
David Payne
David Payne
