Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Proper hookup for 32'' Emmerson hdtv
Our tv was stolen and need to know how to hookup the new one (32" Emmerson). the old one was hooked up with several cables. I don't think I'm getting HD and I have to turn on and adjust the volume with the remote that comes with the tv instead of using the remote that comes with Dish DVR
    Problem Solver:
  • 17 Answers
If you have a 625 receiver your no going to get hd from this receiver
Posted on Nov 23, 2008
I have a 32" emmerson and the color is not right.
meau -setting- picture or display reset defaults or adjust to your liking.
depenting how old the tv is the picture does go after time.
Jan 02, 2013 | Televison & Video
Game console hook up
What type of hookups are on the back of tv ? Do you have an HDMI hookup if so try using that If your tv comes with a game mode look in back before u hook it up to place it in right spot. One last thing why don't you try hooking up old fashion way buy adapter for regular cable hookup and use channel 3 or4 that might help
Jul 30, 2012 | Mitsubishi CS-32307 32" TV
How do you hook up laptop to tv
Great day Barry!
You need a 15-pin VGA connector to hookup your laptop to your RCA L32HD31 through the VGA ports.Please see attached image.11_19_2011_6_49_41_am.jpg
Nov 19, 2011 | RCA L32HD31 32 in. LCD HDTV
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
Trying to hookup old dvd/vcr to new flat screen. have cable box hooked up nad working. dvd/vcr no hdmi connections. what cable hookup do I use
You need to use composite inputs. They have three connections, yellow for video, white for left audio and red for right audio. It does not matter which input you go into. I would imagine there are about 7 separate inputs like the ones I described, just remember which one you use because you will have to set the input to that number to see the VCR/DVD later. Get a phono or RCA patch cable and connect the same colors from out on the vcr/dvd box to in on the tv. Turn everything on, set the tv to the proper input using the menu or input selection and you should be able to view video tapes or dvds. Let me know if you need more help.
hardrocko
Feb 01, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Element 32'' LCD TV, has picture but no sound
The S-video cable doesn't have hookups for audio, only video. It's better than the video coaxial cable. But, you still need to hook up the right and left audio coaxial cables.
Feb 09, 2009 | Element ELC-HS321 32 in. LCD TV
Need to know how to hook up 32' HDTV with DishTV satellite hookup
It seem that you maybe mistype the model number , take a look there http://www.tacp.toshiba.com/televisions/lcd/product.asp?model=32av50u this tv seems to fit yours , if not look at the other one and go in resources , there you can download the manual for your television , i own a toshiba lcd too and its pretty easy to plug i just plug it behind , use to remote input buttom and that it , just make sure you plugged the satellite dish cable at the good place behind your satellite receiver maybe it could be the problem too .
Jan 25, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Emmerson HDTV f32
The failure with this LCD might be due to a failing power supply or backlight inverter board. Since your TV is less then a year old, I would suggest to call the manufacturer to get it fix under warranty.
Good Luck.
Jan 17, 2009 | Televison & Video
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
87 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
