Question about Ariston Technologies AWD 121
Oven shuts down in middle of cooking
When turning the oven on it makes a terible noise while cooking and half way through cooking things the oven shuts down the elements shut down the oven lights turn off however the timer and clock remain on. and after about 1/2- an hour to 1 hour the oven restarts this is very fustrating and i dont know wheather to fix it or replace it, it is only about 5 years old it is an ariston mb91 built in maxi oven
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 31 Answers
I'm only guessing here but it's possible the internal thermostat is broken and the oven is overheating {?} and triggering some built in safety switch that turns the oven off so it won't cause any damage.
I suggest you call the company, or a local oven repair person.
Letting us know if it is Gas or Electric may help too.
Posted on Aug 01, 2017
4 Suggested Answers
dazmaraz
  • 67 Answers
SOURCE: Ariston frontloader - dial spinning around and won't start a cycle
Your bearings are almost certainly gone which would explain the noise not an easy job or cheap . Normally it would consist of a tub change or at best a bearing hub . As for the clicking round of the selector Iwould suggest poss the heater or brush fault. As ofr price you'd have to ask your local repair man. Worst case sinario approx £200 .00
Posted on Jun 28, 2007
  • 251 Answers
SOURCE: Ariston AWD 121 wont work
make sure the water supply is turned on , a small red and blue tap usually under the sink
Posted on Nov 11, 2009
  • 41 Answers
SOURCE: Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Posted on Jan 09, 2010
I have an oven that does not cook evenly. Which dial should i be cooking pastries at so i get an even cook from top to bottom
they do not recommend using all shelves at once . use middle only and rotate goods half way thru the time of the bake
Aug 02, 2017 | Ovens
Oven shuts off in middle of cooking/baking. stove top burners work just fine.
GE oven - SHUTS OFF ON IT'S OWN
I have a built-in GE Electric oven - model #JTP20B0F7BB. It shuts off in the middle of cooking sometimes, but not all of the time. It does it about 1 out of 4 times that I use the oven. Any help would be appreciated?
Apr 17, 2011 | Jenn-Air Ovens
Range modle is KGSS907SSS01.when i cooking or use the oven, some noice come out ,until over is off or the temperature is down.
is it possible the coolant fan is running and has started making some noise ...the fan will come on at temperature request it has a thermostat to bring it on when the oven gets hot enough and will cool down...sometimes the fan will run even when you turn the oven off if it is hot enough until the temperature gets down low enough to shut it off...maybe this is what is going on and the fan has started making noise now and will need to be replaced.... good luck to you
Jan 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
My food no longer rotates while cooking,and it makes a clicking noise.
this is usually a bad turn table motor. if you remove the screws out of the bottom of the otr(over the range) it will hinge down and back and you will see the motor in the middle of the otr. your local parts house should have this item in stock or be able to order it for you
Apr 24, 2010 | GE Advantium 120 Convection/Microwave Oven
The oven we have, model 70131, is taking longer to cook things then it should. i've also noticed it'll make a loud popping noise as it gets up to temperature. is there a way to fix the problem?? it's...
it might take some time but get a new thermomiter and pick 350 leave it threr for a half hour check it move the knob a little at a time till you get it close and mark the knob if you can see through the glass watch it close it will go up and down by about 50 to 60 deg or less your looking for the average in the middle of the high and low this what it's set at if you have moor than 60 deg sweep you need a new thermostat and no amount of adjusting will help it bake right the lower the sweep the better it will bake
Dec 08, 2009 | Maytag Ovens
hI.
What is the make and model of your cooker?.
I do not know the answer at this stage, more information would help.
Cheers
Nov 23, 2008 | Ovens
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Lower oven
hi
shut off power to the unit, let it sit for a while then turn the power back on. test the oven again, if the code comes back call 1-800-Jenn-Air and ask them what the code means.
Apr 02, 2008 | Jenn-Air JJW8430D Electric Double Oven
Only half cooking
Theres a handy conversion table here:- http://www.hintsandthings.co.uk/kitchen/oventemp.htm Regards
Sep 26, 2007 | Frigidaire FGB24S5A Gas Single Oven
Ariston Technologies AWD 121 Logo
51 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
