Question about Rosewill 1 Bay (RX50-U2FA) Firewire/USB Combo External Drive Case
Problem with rosewill 1 tb external hard drive
I made the mistake of backing up my whole computer on the external hard drive and now I cannot access it at all...What can I do to delete what I have on it..When it boots up I cannot get An Icon and my computer loses all of its Icons??Thanks...
  • 6,831 Answers
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Posted on Sep 29, 2010
Laptop suddenly will not recognize my external hard drive
One thing to try is hooking it up to another computer. There is a possibility that the hard drive failed or the controller for the external storage device has failed. If it is recognized on another computer then I would look at the manufacturer's website for an updated driver
Dec 05, 2017 | Rosewill Computers & Internet
Tips For Choosing External Hard Drive
External doesn't necessarily mean portable.
Not all external drives are acceptable for portability. Most external drives are fabricated of cheap, non blemish aggressive and accessible to breach plastic. If you are attractive for a carriageable adamantine drive and abstracts is important to you, you are best off selecting a metal case alien drive. You can alike acquirement a waterproof adamantine drive or one with added shock resistance.
Size comes next.
Today's external drives appear in all sizes and added recently, shapes and colors. As with added computer accompanying accessories - pink, red and dejected are in fashion. All drive cases from the antecedent bearing looked like a big animal brick but things are altered today. Smaller, abridged admeasurement adamantine drives are added big-ticket as able-bodied but they've yet to ability capacities of 1 TB or more.
Capacity is most important.
Today's external drives accept capricious accumulator capacities, starting with 160 GB and catastrophe with 2 TB. With the accretion admeasurement of media files, it doesn't do amends to access a low accommodation drive and pay added per gigabyte of storage.
on Dec 29, 2010 | Computers & Internet
1 tb internal hard drive recognised as 300gb?
Please check it:
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. What is the information of your 1 TB hard drive? Is there any unallocated space?
Mar 02, 2014 | Western Digital WD My Passport Essential...
I have the simple tech 1 tb external hard drive, I updated my mac OS and now my drive can no longer be read or opened???
Apple will recognize a FAT 32 format. Connect the drive to another machine - a PC. Copy your data to this computer, format the drive to FAT32, copy your data back and it chould be accessable to the MAC system again.
Sep 23, 2011 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
Problem with Accessing Western Digital WD My Passport Essential SE 1 Tb external driver, please guide to resolve problem with windows XP
Go to Control Panel - Administrative Tools - Computer Management Then go into Disk Management. Hopefully you will see a drive with a capacity of about 480 GB (plus or minus), that's your disk.
Right click on it and select change drive letter and change the drive letter to something that isn't in use.
If that doesn't work or it doesn't show up, go into the Device Manager from the Computer Management screen and see if there is anything under disk drives with a yellow or red symbol next to it. If so, right click it, select uninstall, then unplug the disk drive and plug it back in.
Feb 27, 2011 | Western Digital WD My Passport Essential...
I bought a WD5000BEV harddrive in december 2009 and within 6 months it has started giving me problems. Sometimes the computer recognises it and some times it does not. Even thought it appears on the...
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Western Digital External USB 2.0 80 GB...
Hi im sachin want to purchase 1 tb hard disk of cgate and LCD of ither samsung or sony.... 1. will support an external USB hard drive on this lcd's ? there any other type of hard disk i need to...
I do not know if the 1 Tb external hard will work on the USB ports on the LCD TVs.
What do you want to store on the 1 Tb USB hard drive and display on the LCD TVs?
Most LCD TVs can access USB memory sticks and display DVI movies (if supported by the TV), photos etc. that are stored on these USB memory sticks.
Try inserting an USB hard drive (borrow one if necessary, can be any capacity) into the USB port to see if it works before you decide to purchase a 1 Tb USB hard drive.
My suggestion would be to purchase a 1 Tb USB memory stick. This would out perform an external USB hard drive.
May 19, 2010 | Dell Dimension 3000 PC Desktop
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
Dec 31, 2009 | Western Digital My Book Essential Edition...
OS whont start whit WD 1 TB external drive.
You need to set your boot sequence in the BIOS so that it does not include external drives. Basically your computer is trying to load Windows from the external drive instead of its own internal one.
Your motherboard manual is going to help, if you can't manage it by yourself give me a link to your manual or tell me the model of your motherboard and i will show you what you need to change.
Oct 03, 2009 | Western Digital MyBook Studio 1 TB USB...
Open Questions:
See all Rosewill 1 Bay (RX50-U2FA) Firewire/USB Combo Questions
Rosewill 1 Bay (RX50-U2FA) Firewire/USB Combo External Drive Case Logo
123 people viewed this question
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
