Question about Panasonic KX-TG2631 Cordless Phone
Change pulse into tone
My panasonic corldless phone model no. kx-tc1015bxb is not working, how to change pluse into tone?
  • aks_cb Nov 22, 2008
    how to change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Posted on Mar 23, 2009
Where can I get a telephone manual for Panasonic KX-TG2205W
Hope this helps
Panasonic Telephone KX-TG2205W User Guide ' ManualsOnline.com
www.manualsonline.com > ... > Communications Panasonic > Panasonic Telephone
2.4GHz Digital Cordless Phone. Model No. KX-TG2205W. Pulse-or-tone dialing capability. OperatingInstructions. Charge the battery for about 15 hours before ...
Apr 02, 2017 | Panasonic Lands Phones
Changing from pulse to tone panasonic phone
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
The manual for the Panasonic KX-TG5664 is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/KXTG5664.PDF . See page 17 for setting the Dialing mode.
I hope this helps.
Apr 06, 2013 | Panasonic Lands Phones
I have got a Panasonic KX-TG7220NL. Cannot change from pulse back to tone. How to do that?
First of all, here is the main ONLINE SUPPORT page for your model:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Bluetooth-Enabled-Systems/Operating-Instructions/model.KX-TG7622B.O#ts
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/KXTG7622-MUL.PDF
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 18 of the manual for detailed instructions on how to switch between TONE and PULSE dialing. Basically it reads as follows:
Dialing mode
If you cannot make calls, change this setting according to your telephone line service.
The default setting is "Tone".
"Tone": For tone dial service.
"Pulse": For rotary/pulse dial service.
1 - MENU # 120
2 - Use UP / DOWN arrow keys to select the desired setting.
3 - Select SAVE and then OFF
I hope that was helpful to you, good luck and take care.
Joe.
Aug 26, 2011 | Lands Phones
There is no "magic switch" on the back of this
The magic switch is in the SYSTEM. By default Panasonic systems are Tone dialing. You can change it or if you press # it turns off tone to pulse conversion.
Carl
Jan 31, 2011 | Panasonic KX-T7730 Corded Phone
How do i change from tone to pulse on panasonic kx- tg6511 cordless phone
Try this.....Press menu....enter (# 1 2 0). Now select up or down key to get tone or pulse. Then select Save then off.
Nov 10, 2010 | Panasonic KX TG6511 Cordless Phone
Both phones have no dial tone and don't work - could it be because they don't support digital?
Hi, Welcome to FixYa.
The cordless phones supports pulse dialing than tone now a days.
If your provider supports pulse dialing & tone you can just change the tone to pulse to use cordless phone. Otherwise you have to request for pulse dialing from your provider.
We appreciate your feedback; it will help us improve this Web site.
Please select 'YES' if satisfied.
Jul 08, 2009 | Panasonic KX-TG2352 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Is it possible to change from pulse into tone on Panasonic phone KX A145? I can't find this function on the phone. Does anyone know if it exists at all? Is there any general rule that may apply to all...
On this side of the pond, a KX-145 is a drum for a KX-F3000 fax machine with phone ! If that happens to be yours, under the * key, there's a stencil that says TONE. If you are trying to convert all calls to tone, then try the panasonic web site and look at the nameplate on the machine for whatever it happens to be.
If the search engine screwed up, then look to use the # key or a tone/pulse switch on the side of the phone.
Carl
Apr 11, 2009 | Lands Phones
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
Jun 19, 2008 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG2631 Cordless Phone Logo
719 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
