Question about Candy Washing Machines
Washer wont work
Hi when turn the washer on it fills up with water then nothing happens but it drains allright can you help.
  • paulscott65 Nov 22, 2008
    the washing machine is a candy grand 1400 AAA class i believe, also theres a number on it GO 1482 am not sure if that will help?
  • 903 Answers
Does the programmer move or make noises?
It could be one of four things
Faulty programmer (if it does not move or make noises)
Faulty Door lock, (try pushing the door firmly in)
The belt may be broken - If the belt is broken or come off of the wheel then you will be able to see this by removing the top. (always make sure that you remove the electrical plug before investigating)
The brushes on the motor could be worn down
Posted on Nov 22, 2008
KENMORE OASIS WASHER DISPLAYS Ld CODE AND WILL NOT DRAIN WARER FROM TUB
I have the kenmoe Oasis he and out of no where this machine wont work. You push the start button and select and that is it 'Nothing" you have to unplug it and start over again but the same thing will happen "nothing" and plus the water wont drain! I feel this is a rip off machine. house wife
Dec 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Indeset washing machine has stopped working. You select the programme the green light comes on but nothing happens. It in not filling up/ draining/ spining nothin, Can you help????
this may sound silly but just had the same problem changed the pump and it works fine now, if the pump does not work it wont let the washer start
Oct 18, 2010 | Indesit W 123 Front Load Washer
My washer wont drain and when i try to start it over nothing happens. last time i was able to drain the water but when i put in another load, the washer filled with water and wouldnt drain again. Help what...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Fisher Paykel EcoSmart GWL15
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Dec 19, 2008 | Maytag HAV3460AWW Top Load Washer
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Just hooked up and it won't keep water
The drain pipe is one of the following
a) shoved wayyyyy to far the drain pipe
b) lower than the water in the tub
c) clamped tight to a drain line
Jan 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
164 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
