Question about E-Machines eMachines Monitor E15T4
Reddish Screen Color
Lately, I've noticed my monitor flickering. It is a 17" flat screen, less than a year old. It will go on like that for awhile, but every so often the screen will completely turn to a reddish tint. It will stay that way for awhile, then go back to it's proper coloring, but the flickering is still there. Tried doing some research to see if I could figure out the problem, but I have no real knowledge of how to trouble shoot and hope someone here may have a solution or at least an answer as to what it wrong with it. Thanks! :)
Hi:I have a Acer monitor,and on the bottom of the screen,where the task bar is and all along is discolored,The monitor isnt that old,2 years,maybe less.
What does the discoloration look like? Is it a pinkish or reddish color tint. This usually is the LCD inverterespecially if it is that slightly pink color and when it comes from the bottom of the screen. I could be wrong....
Thanks!!EJ Kudelka
Oct 11, 2011 | Computers & Internet
Reddish picture when power on, screen flickers and then shuts off after 1 or 2 minutes
The red or pink color indicates one of the backlight tubes is failing. Only solution is to replace the bulb or replace the unit.
Monitor Mike
Jan 17, 2010 | HP L1706 17" LCD Monitor
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
I have noticed recently that the screen words flicker.
If the monitor is less than a year only, then your best bet is contact the manufacturer for warranty support.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Jun 14, 2008 | Acer AL2017 20" LCD Monitor
Monitor flashing
I have a similar problem with my screen, same one, 15". For a period of two years it would turn black for an instant and resume functioning. Since two weeks it only flashes the picture for an instant and then turns black again. We opened it up to check the wiring but nothing wrong there. We are 99.99% sure that the problem is in the screen itself and has nothing to do with drivers or anything else in the computer.
If you bought it less than 3 years ago and since it is probably a result of faulty construction, it should fall under warranty (by european law).
I am going to take mine to a repairman tomorrow, i will inform you wether the screen can be repaired or not.
Greetings,
Rengenier.
Oct 10, 2007 | LG Flatron L1715S 17" LCD Monitor
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
E-Machines eMachines Monitor E15T4 Logo
146 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
