Question about Kenmore Washing Machines
Kenmore (417.40042990) goes off balance on spin cycle but on high spin it is bouncing just about hitting the sides and front to back.
  • Anonymous Feb 02, 2009
    can not get my machine to balance
  • 116 Answers
INSPECT SHOCK THREWING OFF BALANCE
Posted on Nov 30, 2008
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer bangs loudly in middle of spin cycle
Make sure the back spring is still on the back of the tub. That tends to come off sometimes. Check all the other springs while you're down there too. You can balance the unit if you tilt the back side of the washer and then set it back down. it has auto leveling feet. What's happening is once the water is all drained out, the unit will enter the final spin cycle and spin very fast putting the unit off balance so the tub bounces around.
Good luck, let me know if this helped.
Aug 10, 2009 | Kenmore 23012 Top Load Washer
Bounces everywhere on spin cycle, just moved from NY. Can I balance this thing.
something is loose in in the drum/shocks/shaft area, unless you are washing sneakers in it
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
I have a Kenmoer front load washing machine that doesn't spin.
You have an issue with your off balance detection program.
The problem could be at the motor control unit (MCU) or the central control unit (CCU). The quickest, easiest and least expensive one to replace is the MCU.
Take off the front access panel (at the bottom, held on with three screws). The MCU is located on the left hand side. It looks like a white (or off-white depending on the age) box.
Open the plastic flap on the front of it, and disconnect all the quick connects (make sure you mark them so they go back in the same spots).
To remove the MCU from the bottom of the cabinet, there is a locking tab on the front tab. Lift that, and slide the whole unit forward.
To replace, do these steps in the reverse order.
Feb 07, 2009 | Kenmore HE2 Plus Front Load Washer
Off balance
make sure you have all the shipping material out of unit..4 bolts in back and styrofoam under tub if so ,then get a adjustable wrench ,,,put unit in drain spin cycle or spin cycle only..when unit gets to fastest spin ,,thats will come when its about 8 minutes left..tighten each leg lock nut on unit until unit stops vibrating..only turn the lock nut not the leg..only adjust lock nut on legs in high speed spin
Dec 25, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 46462 powers off during spin cycle - no lights
i cleaned out the pump under the front bottom panel
Feb 03, 2008 | Kenmore 46462 Front Load Washer
Kenmore front loader goes off balance
My front load kenmore washer tub bounces really hard before going into a full spin. can anyone tell me what is wrong with this. thank you
Aug 31, 2007 | Washing Machines
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
89 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
