Question about Mitsubishi VS-1250 TV
TV Whines Mitsubishi Black Diamond 27" 3 years old. Infuriating whine from TV when turned on. If I turn it on and off about 6/10 times, whine goes away. Brought to service engineer three times in last two months. Claims he cannot hear any problem. He's in his sixties, so maybe he can't hear the same pitch as me. It's driving me bonkers. Any suggestions?
tvtek
  • 1284 Answers
SOURCE: mitsubishi black diamond tv
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Posted on Apr 07, 2007
techworm
  • 56 Answers
SOURCE: Mitsubishi WS-55807 Picture goes out ... clicking
flyback
Posted on Nov 12, 2007
  • 21 Answers
SOURCE: Mitsubishi Diamond TV power went out TV wont turn back on.
the regular problem is the convergence kit,
Posted on Jan 20, 2010
jdvillanueva
  • 2098 Answers
SOURCE: mitsubishi diamond vision 27" 1995
It is an indication of leaky electrolytic capacitor on the vertical section.
This is not a diy if you are not an expert.
I've adviced you to look for a qualified technician to replaced the faulty capacitor.
This is quite fixable and easy to locate by the technician.
pls rate my help...
Thanks for using fixya.
Posted on Jan 14, 2011
SOURCE: I have a Mitsubishi CS-40509 TV. It is over 12
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then few TVs ( not all TVs ) behaves exactly as you have described.............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally ----- though it is 12yrs old itseems TV TUBE is still in good condition because you have said that when display comes picture is clear......so if EHT ( same type) is replaced then your TV will work atleast for 2 more years.....GUARANTEE.......
Posted on May 22, 2011
My rainbow whines when I turn it off
My Electrolux whines too and has been whinned since about 3 years. If it works, don't worry and let it whinning.
Feb 06, 2015 | Rainbow Vacuums
Mitsubishi diamond vision 27" 1995
pls rate my help...
Jan 14, 2011 | Mitsubishi CS-27205 TV
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
May 24, 2010 | Vivitek V37655 56" DLP TV
Rainbow E2 2 speed vacuum motor whines at startup
I used to sell rainbow vacuums and this latest 2 speed model does whine when it is first turned on. So you definately have nothing to worry about. I believe this is due to the fact that this motor is much more powerful than in the previous 1 speed E series model. I finally just purchased a 2 speed model after many many years of wanting one. Good luck to ya and enjoy your clean house!
Feb 18, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My 2003 Ford Windstar whines when turning the steering wheel.
The power steering pump has gone bad. Consider replacing it because if serviced it will still show this sign in a little while.
Good luck.
Rate this solution
Aug 24, 2009 | 2003 Ford Windstar
Mitsubishi 1080 diamond tv screen turns off
Your tv has a lamp inside (refer to your user's manual) make sure is in good condition.
Mar 21, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Hp monitor whines
THIS MEANS THE MONITOR MAYBE GETTING OLD OR WARNING OUT FROM SO MUCH USE AND IT IS TIME TO BUY A LCD MONITOR.
ROD
PS YOU CAN HAVE THE OLD ONE FIX IF YOU WANT BUT I THINK YOU SHOULD GO LOOK AT THE NEW ONE AND FALL IN LOVE WITH THE PICTURE AND LOOSE ALL THE NOISES AND HEAT ALSO.
Mar 13, 2009 | Computers & Internet
Mitsubishi black diamond tv
Apr 07, 2007 | Mitsubishi VS-1250 TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
