Lennox 80 ugh turns on and shuts off in 2-3 seconds
The unit comes on for about 2-3 seconds and the ignitor pin is bright orange. I tried it several times and it did the same thing. The gas ignites but then goes out. Any Ideas????
  • bcpdduke Nov 25, 2008
    I cleaned the sensor off and it still did it, so I cleaned and repositioned the flame sensor and it started to work. I dont know if that fixed it but a turned everything back on and it worked.
    Thanks for all the help.
  • 34 Answers
You may need to clean the flame sensor, esp. if the gas is coming on.
Posted on Nov 24, 2008
Black decker cordless drill ldx120 runs for a second and shuts off, battery fully charged and the led light comes on and is bright.
The brushes on the motor may be worn . The battery may have several bad cells in it. The led lite only needs 2 volts for full brightness.
Jan 17, 2014 | Drills
Lennox 80 ugh furnace turns on, small blower runs, igniter does not glow nor do burners ignite. After cycle one led off other steady blink ?
check for power to igniter leads on a call for heat if voltage present then ignitor is bad. if no voltage present then board output bad.
Oct 09, 2013 | Heating & Cooling
Flow plug
even though the ignitor seems to glow bright orange,it still maybe weak,as in not enough current to open the gas valve,an easy test is to just swap out or interchange the broiler ignitor and bake ignitors and see if this takes care of your issue on the lower bake side as most units use the identical ignitor for each upper and lower manifolds and the gas valve supplies both the bake and broiler manifolds depending on which you choose to use bake or broil
May 28, 2012 | Jenn-Air Chef Gas Oven Range Ignitor Flat...
Furnace starts up blower starts..nothing ignites...then shuts down. repeats and doesnt stop...sanded igniter stick and nothing happend. flashes red once.
Do you see the actual ignitor glow? You must be saying that you sanded the sensor. The ignitor, after the little inducer fan comes on will begin to glow a bright orange until the burner lights. If the ignitor is broken, you will NOT see a glow, and you may smell a faint smell of gas.
Apr 14, 2011 | Goodman GMS90703BXA Heater
Furnace ignitor comes on glows little red gas comes on doesnt ignite gas shuts off ignitor comes back on glows bright orange gas comes on and ignites. It started doing this right after I replaced the...
Check your conection off the board to the initor and make sure the pins in the plug are set tight with the connection on the board. If you wire nutted the wiring together for the new ignitor you installed check these connection also. Make sure all wire strands at the wire nuts are in the wire nut and not touching or arching on the furances cabinate.
Jan 31, 2011 | Goodman GMS90703BXA Heater
Turns on but. Will not heat upb
The areas that come to mind is the ignitor and/or sensor has gone bad The most unlikely is the gas valve but it is a possibility. I check for a thermal fuse on your model It does not come with one. That eliminated another cause.
Attached is a picture for reference.
When the dryer is turned on, the ignitor ( #74) will start to glow and in a few seconds to a bright orange color. The sensor ( #79) which is located on the outside of the flame tube, detects the heat intensity from the ignitor. Once the ignitor has reached its limit when operating correctly, the sensor will give a signal for the gas valve to open and release gas through the burner where the ignitor will light the gas. This process repeats several times when drying a load.
Defective ignitors will either have no glow or the will glow a little bit.
Hope this helps you out.
Always you caution when working on appliances.
Nov 16, 2010 | Frigidaire GLGQ642A Gas Dryer
Where is the ignitor for lennox LF|24 - 45A garage heater
hi should be by the burner a elctroed rod or a permant pilot you need to be up leval with the burner they are some times not easy to find try and follow the pilot line if there is one or a orange electrode wire ,
Jan 16, 2010 | Heating & Cooling
The unit will turn on and run fine for a few minutes then shut off. It won't immediately turn back on, almost as if it hans to cool back down first. Any ideas i have a lennox furnace
The ignitor will light, the blower will start up and run for a few minutes and then the system will shut down, and the blower will continue to run and cool down. The ignitor is not working properly, the ignitor has carbon build-up and need to be removed, cleaned all the black carbon from the ignitor with a little piece of sand paper and replaced, turn the heat back on and this should correct the problem.
Dec 12, 2009 | Heating & Cooling
Oven's ignitor is bright, I smell gas, but it won't lite.
if ignitor is brt orange to white its hot enough to ignite gas,either the flame sensor is giving wrong signal to control board and not opening gas valve or signals the gas valve to shut off gas before ignition,also your flame sensor could be faulty or control board is bad
Jul 26, 2009 | Kitchen Ranges
Lennox 80 ugh furnace turns on, ignites gas and shuts off in 2-3
I can appreciate in the fact that you do not want to offer a solution to my problem without paying money however you would like me to tell you how I fixed my problem for free, if you would like to know how I fixed it, how about you subscribe to my premium plan and I will tell you.
signed,
Not impressed
Nov 22, 2008 | Heating & Cooling
Heating & Cooling Logo
204 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
