Question about Sony Handycam DCR-DVD105 DVD Camcorder
Memory Stick I would really appreciate if someone could heplout. I am trying to locate the spot to insert the memory stick for the camcorder.
  • 488 Answers
As per the product details there is no memory stick slot..please look at this link(i have gone by the model number post)look at convinience..hope it helps!
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11038668
Posted on Nov 22, 2008
Memory stick not working
could be a faulty memory stick or could be a faulty camcorder. see if you can borrow another stick or cam to try them, failing that ask you electronics store to test them, they should do it for free....and then sell you something that works ;O)
Make sure the memory stick connectors are clean and the slot on the camera also. put the stick in and out fast 3 or 4 times. The contacts should be gold and not corrode but it doesn't stop a layer of dirt forming
don't want to call you dumb but for anyone else's benefit; double check the stick is the right type. and a compatible storage size
Jan 08, 2012 | Sony DCR-DVD608E DVD Camcorder
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
May 02, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Toshiba Satellite will not recognize Memory Stick Adapter
Try downloading the drivers for the sony memory stick from their website, than it should work fine.
Jan 02, 2009 | Computers & Internet
Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
Nov 13, 2008 | Sony Handycam HDR-CX12 Flash Media...
Memory stick recording
that means your camcorder is set to record on the disc not on the memory card. try to look on the settings on your camcorder there's an option fo you to choose like disc or memory card to be use as recording. hope that helps!
CHARCOIS
Sep 18, 2008 | Sony Handycam DCR-PC105E Mini DV Digital...
Memory Stick Error
Go to camera menu and Format memory stick then try.
Sep 06, 2008 | Sony Handycam DCR-TRV340 Digital Camcorder
Memory card error
did you already formated your memort stick? try to remove your memory card from your camcorder and insert it again. look for the settings on your camcorder. it might cause the problem. hope that helps!
CHARCOIS
Aug 17, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Memory Stick Error, PLEASE HELP!!!
Does any other Sony memory stick still work in your camcorder? If yes, means memory stick isn't match with this camcorder. Use Sony memory stick.
Jun 09, 2008 | Sony Handycam DCR-TRV20 Mini DV Digital...
Memory stick error
hi bubba9
if you are using the handy cam just look at the specs on the manual to determine what memory card is compatible. based on your info it is unlikely that the camera even supports 4gig of memory. You should try the smaller sony memory stick up to 2gb only and it should work. good luck
smeags.
Dec 31, 2007 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony Handycam DCR-DVD105 DVD Camcorder Logo
67 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
