Question about Microsoft Office Professional 2007 Full Version for PC
Want to know about macro excel - Microsoft Office Professional 2007 Full Version for PC
    Scholar:
  • 135 Answers
Here are some useful links
www.microsoft.com
www.helpwithpcs.com
I hope from these links you will know what is macro and why we use it and how to use it.
Regards
Posted on Nov 22, 2008
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
How to create macro button in microsoft excel 2007 because
well follow the steps below to get your job done:
To create an option button in Microsoft Office Excel 2007, make sure that you add Option Button (form control) to the Quick Access Toolbar. To do this, follow these steps:
  1. Click the Microsoft Office Button, and then click Excel Options.
  2. Click the Customize category, select All Commands in the Choose commands from list, select Option Button (form control), and then click OK.
To create an option button and to assign a macro to it, follow these steps:
  1. In Excel 2003 and in earlier versions of Excel, click Option Button on the Forms toolbar, and then draw the outline of the button on the sheet.
    In Excel 2007, click Option Button (form control) on the Quick Access Toolbar, and then draw the outline of the button on the sheet.
  2. Select any cell in the worksheet.
  3. In versions of Excel that are for Microsoft Windows, right-click the option button, and then click Assign Macro.
    In versions of Excel that are for Macintosh, press COMMAND while you click or press CTRL while you click, depending on your operating system version. Then, click Assign Macro.
  4. In the Assign Macro dialog box, click the name of the macro that you want to assign to the option button, and then click OK.
When you click the option button, the macro will run.
good luck ...:-)
Apr 08, 2010 | Microsoft Office Excel 2007
Help: excel 2007 suddenly hangs when working with macros
check the physical memory,and also if the excel file size,if the file size is so big then it gets hang
thanks
Feb 17, 2010 | Computers & Internet
What do you mean excel macro
is a hiden process of Excel, is like program or several steps ( like moving cursor, make calculations, moving files, is no limit what can do, but normaly is not visible, is low level programing is always used for virus spreeding.
Jan 14, 2010 | Computers & Internet
Whenever I open a new spreadsheet now it automatically opens up a spreadsheet calles PERSONAL. Why is that and how can I get rid of it... I think it started after a did a macro but I am not sure. Thanks,...
You're right - it was caused by recording a macro. When you record a macro you are given the option to store the new macro in "This Workbook", a "New Workbook" (the default), or in a "Personal Macro Workbook". It looks like you selected "Personal Macro Workbook".
The recorded macro is stored in a special workbook called "Personal.xls". This workbook is loaded every time Excel is loaded. If you don't want this workbook loaded, then just delete it or rename it.
The file is buried deep in Microsoft's application data area. On my Vista computer it's in C:\Users\frogfund\AppData\Roaming\Microsoft\Excel\XLSTART On my Windows XP computer it's in C:\Documents and Settings\frogfund\Application Data\Microsoft\Excel\XLSTART. Depending on your computer your Personal.xls might be in a slightly different location. You might need to do a search using Windows Explorer.
If you are still having troubles finding personal.xls 1. Open Excel, 2. Open the Visual Basic editor (hit Alt-F11 or click Tools-Macro-Visual Basic Editor) 3. Click Tools-References to bring up the references dialog 4. Click on VBAProject in the list. The file location will be displayed near the bottom of the dialog box. Sometimes this might be cut off at the end, but it should give you a good idea where the file is located. 5. Click Cancel to close the dialog.
Sep 23, 2009 | Microsoft Office Excel 2003 for PC
Macros
After you record your macro do the following.
Open the excel file contains the macro. Go to tools and go to macro and click on macros. Select the macro you wish to add the close operation. Click on Step into... This will open up the visual basic editor. In the code window, at the bottom row you will see End Sub. Right before that row, type workbooks.close
Save the macro by clicking the save button. And you can run your macro to see if it works. I tried, it does :) Good Luck :)
Aug 18, 2008 | Microsoft Excel for PC
Macro
Hi motilal
Follow these steps to create multiple macros
Click the Microsoft Office Button , and then click Excel Options.
In the Popular category, under Top options for working with Excel, select the Show Developer tab in the Ribbon check box, and then click OK.
Note The Ribbon is a component of the Microsoft Office Fluent user interface.
To set the security level temporarily to enable all macros, do the following: On the Developer tab, in the Code group, click Macro Security.
In the Macros Settings category, under Macro Settings, click Enable all macros (not recommended, potentially dangerous code can run), and then click OK.
Note To help prevent potentially dangerous code from running, we recommend that you return to any of the settings that disable all macros after you finish working with macros.
Open the workbook that contains the module that you want to copy and the workbook that you want to copy the module to.
On the Developer tab, in the Code group, click Visual Basic.
On the View menu, click Project Explorer .
Drag the module that you want to copy to the destination workbook.
Regards,
TheAssembler
May 06, 2008 | Microsoft Excel for PC
Macro in excel
Open up your Excel and hit ALT + F11. This opens up the VBA editor.
You can then right click and click New Module and write your macro in there.
Mar 22, 2008 | Microsoft Excel for PC
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Jan 28, 2008 | Computers & Internet
Macro to be used in Excel
Instead of me teaching u. i would suggest u learn it by following the simple steps.
1. Click Tools > Macros > record
2. do some common operation like copying data, creating graphs, etc.
3. press alt+F11 to go to vb editor, to see ur macro recorded
4. study it ... u will learn easily
or
try the book 'Microsoft Excel Visual Basic Macros Examples' at http://www.add-ins.com/vbexamplestopics.htm
bye
have a nice day
Jan 26, 2008 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
