Question about ASUS P4S800-MX Motherboard
Computer will not boot
Please help me with this problem. My PSU was faulty so I replaced it with one of the same specs. I am now unable to boot the PC. When I press the on switch nothing happens. I can see that there is power to the mobo because the light comes on.
I disconnected power to all peripherals and removed all cards to see if the PSU will at least spin up when I pressed the on switch but still nothing happened.
Does this mean that the motherboard is fried?
  • Ryan
    Ryan Nov 22, 2008
    Thank you. I will try this and report back.
    Problem Solver:
  • 19 Answers
This board requires the 12vATX power connector to be connected, have you done this? It is the four pin connector next to the 20 pin ATX (ATXPWR1) board connector. (Looks very much like a graphics card power supply)
Also, make sure that you have not disturbed the 'power connector' on the system panel connector (lefthand front corner of the board). And that the switch is not goosed. You can check this by shorting these two 'power' pins with a small flat bladed screwdriver.
You should also check the voltage outputs on 'Both' the connectors for correct voltage, it wouldnn't be the first time a faulty PSU had been supplied. And of course, check that the power switch on the PSU is set to 'on'!
Bluray
Posted on Nov 22, 2008
  • 93 Answers
Option 1 :
Remove completely the mother board from Cabitnet.
Try to check it on other Cabinet.
Option 2
Remove mother board and re- plug the SMPS power Connecter to Mother board outside of cabit and make sure that motherboard is not touching directly to Metal part of cabinnet.
then switch on computer and check
Pc wont boot, MCP73PVT board, i have checked the ram, processor, heat sink and psu,cmos batt and still no joy, its starts for 4 seconds and turns off, all fans come on but nothing else no beeps
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 21, 2011 | Packard Bell (181368) Motherboard
Power up -- on boot will not boot untill forced shut down the boots up ok
May 16, 2011 | ASUS A8N-VM CSM (00610839133826)...
Hooked everything up all new components, everything meets specs, computer will not boot. M4A88T-V EVO/USB3 motherboard.
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
May 16, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
Hi i just bought an asus m4a88td-m i instaled it with a amd phenom II x4, 500 watts corsair power supply, ati radeon hd 5700 1gb ddr 5 , 6gb ram ddr3 1033mhz and im unable to boot my windows 7 64bits , it...
With all that power, you need a better PSU, the CPU alone draws out 125 watts, the video card can get upwards of 50, RAM takes it down another 25, and that's half of it right there. I would suggest AT MINIMUM a 700 watt PSU. Newegg has em for you (you sound like you can find what you're looking for after all those specs you've given).
I hope this helps!
May 05, 2011 | ASUS Computers & Internet
MY NETBOOK ASPIRE ONE 532H DOES NOT RECOGNIZE HITACHI HTS545016B9A300 SO I CAN BOOT WINDOWS OR REINSTAL IT. please help me
Apr 25, 2011 | Hitachi HTS545016B9A300 160 GB SATA Hard...
I am getting the hp screen and it freezes there it will not enter set up or boot menu just freexes hp pavillion please tell me what do i do
the first thing to test
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 24, 2011 | Computers & Internet
Computer is not booting up. Usual blue light over power switch is red.
hope this will help
don
Feb 15, 2011 | Thermaltake Wing RS 101 Case + 430W PSU:...
HP pavillon dv1000 shuts down for no reason.. Please help.
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 17, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
Hi my monitor will not work and when it starts up it just flashes CD:boot!!! My computer is a Packard Bell 1508/2 Please help!!!
hope this helps
Jan 05, 2011 | Computers & Internet
The computer turns off after 20 minutes and unable to turn it back on
hope this helps
Dec 30, 2010 | Computers & Internet
ASUS P4S800-MX Motherboard Logo
125 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
