Question about Toshiba Satellite M100 Notebook
Noise from power supply
I have a toshiba satellite m100 when i plug in the power supply and listen to music out of the headphone jack there is a loud buzzing noise. and when i disconect the power supply and run on the battery there is no noise what may be the problem
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Hello obs1,
It appears you have a faulty ground from where you plug into the power outlet. You may need to invest in a better surge protector or try another power outlet.
- Vincent
Posted on Nov 22, 2008
When I turn amp on there is a loud humming that does not stop.
try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
Dec 01, 2012 | Fender Frontman 212R 100W 2x12 Guitar...
I have a toshiba m100 and i want to connect it to my tv i have a hdmi output on my tv i am getting a picture but no sound what do i do
You will have a connect a cable from your laptop headphone jack to your audio in on your TV. This is a common problem. They sell a cable that goes from headphone jack to RCA jack size. You could also just add powered external speakers to your laptop and get excellent sound that way. I have a $20 pair of external Labtec speakers and they sound great watching a movie on TV.
Mar 06, 2011 | Toshiba Satellite M100-S5211TD (4400 mAh)
Everytime i plug my headphones into the phone to listen to music it plays through the speaker not the headphones
check whether headphone is plugged correctly - clean the contacts of the headphone jack and the jack base of the phone.
Mar 03, 2011 | Cell Phones
My computer's sound doesn't auto switch from hdphn to spkrs.
Two possible causes one is the headphone jack and the other a driver issue.
The headphone jack has a metal leg that is pushed out of the way when you insert the plug. It then switches from speakers to the jack. That's how it is supposed to work. The third leg can get dirty or bent or loose and not switch correctly. If it is dirty you can sometimes clean it just by inserting it and pulling it out a "few" times. If it is mechanical ie loose then it needs to be replaced which means replacing the main motherboard. You can check for warranty but from experience it might just be one of those things to get used to instead of trying to get them to replace a main board.
If it is a driver all you can do is hope they update the drivers. You can check the drivers versions and release dates on the Toshiba website. Just go to www.toshiba.com then support then laptop and then find your model. Drivers and sort by your operating system. Unfortunately Toshiba seems to have a history of unresolved sound card driver issues.
Nov 04, 2009 | Toshiba Satellite A135-S4527 Notebook
Only noise from PC to monitor through docking station
I have the same problem and tried down loading the lates drivers without any change. It was working fine. I was in the middle of listening to music when it started.
Aug 22, 2009 | Toshiba Dynadock Port Replicator, Docking...
In-ear Headphones
Same problem, not a 'speaker problem" from blowing them out. Try just pushing the jack until you feel resistance and maually hold the jack. You should hear "almost all the music and vocals'. Validates the transducers are ok. Some sort of wiring problem shorting to mic.
Jun 27, 2009 | V-Moda Vibe Headphones
Recently my Toshiba M100-222 model notebook started to have problems when power cable is plugged in. Usually it is not working when power cable is plugged in, but after I unplug power cable and try it to...
Your having a problem with the dc jack on your motherboard. What needs to happen is the motherboard needs to be taken out and there will be solder points underneath the dc jack on the motherboard. These solder points need to be resoldered so that way the dc jack stays in place properly. At this point you should be able to hook up your ac adaptor and use your laptop that way.
Apr 21, 2009 | Toshiba Satellite M100 Notebook
Toshiba Satellite no power
replace only the power jack and clean the power supply board with some alcohol...you can find the jack in some electronic shop..
Jan 04, 2009 | Toshiba Satellite M45-S169 Notebook
Irregular power supply to toshiba satellite M100 laptop
hi there,
i would like to know how old is your laptop.?
new laptop less than a year can operate on 1- 3 hours.
older laptop 2yrs above can only operate at 1 - 1 1/2 hours.
first for an initial help try removing the battery pack and put it back in properly,
let me know again here.
thanks
Dec 06, 2008 | Toshiba Satellite M100 Notebook
Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
