Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
I don't know how to set my self cleaning oven to clean.
I'm trying to set the oven to clean. What do I do?
There's no such setting because there's no build-up of cooking residue - hence self-cleaning. You will need to clean the trays though because it's impossible to make them self-cleaning.
Posted on Nov 22, 2008
4 Suggested Answers
SOURCE: Self-cleaning oven instructions
I've had success with four hours.
Posted on Mar 06, 2008
SOURCE: can't open oven door after using self cleaning mode.
It just needs to cool a few minutes( 15 minutes or less once everything is yurned off) and will open easily, don't force it.
Posted on Jan 13, 2010
heatman101
  • 43501 Answers
SOURCE: how does self clean oven work
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Jun 07, 2010
Don't know how to use the self-clean controls Model C970-535121 serial # NF-40611012
The knob for the oven should have a setting for self cleaning, just turn it on and walk away for a few hours!
Dec 29, 2012 | Kenmore 91112 / 91114 / 91117 Electric...
My older model electric hotpoint selfcleaing range, lower oven self cleaning function is not working. what could be wrong, maybe i didn't set a control knob correctly, don't have a maual for t
Back to the fifties! If the lower oven cooks normally, the heating element probably is OK. For self cleaning the normal temperature setting is bypassed and the heating element is set to a substantially higher level. Your oven may be unable to self clean because operation of the knob may not actually start the cycle. The thermostat could need replacing even though normal cooking is OK.
Sep 02, 2012 | Hotpoint Kitchen Ranges
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
Aug 29, 2011 | GE JKP45 Electric Double Oven
Lost manual and do not know how to use my self cleaning oven. It is a whirlpool. (I don't know what model). What do I set oven on and for how long? Please give me some instructions to use the...
On the front of the oven there is a lever.That is the lock.Lock the oven and then set the temp to clean.Some will lock only when the cleaning starts,others need to be locked first.Try it both ways.
Jun 18, 2011 | Home
Do i have to take out the oven racks before I self clean the oven?
If you don't take them out the high heats can wreck the finish on them and turn them all kinds of crazy colors.... but if you don't care what they look like after the cleaning you can let them in...
My recommendation is to not use the self cleaning feature...
Self Cleaning Oven Problem
It is more like a self destruct feature.... it causes many problems with ovens and ranges from the high heat...
heatman101
Apr 21, 2011 | Frigidaire Ovens
Need to know how to set self cleaning ge p7 self cleaning oven
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
Sep 24, 2010 | GE Ovens
I have a Kelvinator (used) self-cleaning oven with no manual. I would like to know how to set the dials for cleaning the oven.
heatman101
Apr 27, 2010 | Ovens
Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Nov 10, 2008 | Ovens
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
115 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
