Question about Neff U1421 Double circotherm Electric Oven
Neff U1422 oven overheating
My oven is overheating is it the thermostat ? if it is how do I remove it
  • Neff Master
  • 3,463 Answers
Hi
Yes it does sound like faulty thermostat.
You will have to remove the oven from the oven housing, and remove the top cover, and possibly the front console.
Then you will have trace the sensor back to the main oven, and unfasten sensor in oven
You will probably have to remove the rear
panel as well to get the thermostat sensor out.
One other possibility is the sensor may have become detached inside the oven, this will then affect the oven temp.
Good luck
Hope this will prove helpful.
Posted on Nov 22, 2008
Neff U1422 bottom element faulty, is it needed?
the only problem might be hat the oven will not come up to proper temp with out that element .
Oct 16, 2015 | Neff Ovens
Neff u1422 oven where is the element that needs tobe cleaned
behind back panel in oven held on with several screws.
Feb 20, 2015 | Neff Ovens
HOW DO YOU REMOVE CONTROL KNOBS TO REPLACE THE ON THE NEFF B1451 OVEN
I have a Neff B1451 oven and have removed the thermostat knob just by pulling and wiggling it. Thats all you do. If then you want to rpelace the thermostat, there are two screws holding the unit onto the oven which are accessed by taking the silver metal shrouds off first.
Jun 24, 2011 | Neff B1432 Single circotherm plus Electric...
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
I have a Neff oven and it won't heat up.
If it is a fan assisted oven , and the fan is working o/k, then it is likely to be the element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
I the fan is not working as well, then could be a faulty thermostat that controls the heating function.
Feb 25, 2011 | Neff B1691 Single circotherm super...
My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
Jun 10, 2010 | Neff U1721 Double circotherm Electric Oven
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Trying to unscrew bulb cover in a neff oven
no WD-40, turn of the power, break the bulb and remove the base with pliers. More than likely there is dielectric corrosion between the base and the socket and this makes removal next to impossible
Jun 13, 2009 | Neff U1721 Double circotherm Electric Oven
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
Neff U1421 Double circotherm Electric Oven Logo
1,001 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
