Question about Guillemot Force Feedback Ferrari Racing Wheel (2969046) Wheel And Pedals Set
Power supply i got this wheel and i dont have a power supply for it, i was hopping somone could tell me the voltage and stuff like that for the wheel. thanks
Sonta 1996 will not start,i replaced all the sensors,coilpac cheched the ecu,fit universal ign switch and i dont have spark
Do you have power to the coil? Is the coil grounded?The car is old enough that the grounds may be in trouble, so check that all your grounds are good. You will need a volt meter to check if the system is getting voltage where it is needed. If you are getting voltage to everything that needs it and the grounds are good then you may need information about the specific car. I don't know the Sonta so if it has a computer that could be a problem but check the electrical supply and grounds first before looking for big stuff.
Nov 03, 2013 | Wheel Boot Immobilizer and Tire Lock, 12...
2000 gmc k1500 rear wheel hops when turning in 4wd
when 4x4 is engauged it forces wheels to lock, hence when turning one wheel is turning faster than the other causing it to Hop. remember the wheels are forced to turn at exact speed at all times during 4x4 operation, thats why you dont use it on dry areas
Jun 09, 2010 | 2000 GMC New Sierra 1500
Crosley (model# CR711, pink) was plugged into a 240V outlet without a voltage transformer (power requirement for it is 120V) and then smoke came from inside. Now it doesn't work at all. Please can someone...
You definately fried some parts in the power supply, probably a fuse, transforner, and possibly other stuff, impossible to tell without servicing it. You might call a repair shop and get an estimate, then go from there.
Mar 13, 2010 | Crosley Autorama Turntable
My 2001 4wd will go into 4wd hi but...
turn the steering wheel to make a sharp turn to the left or right. if a hopping sensention is felt than the 4 wheel drive is working.
the 4 hi is a locking wheel drive and in a turn,since the outside wheels have to move faster than the inside,it builds up pressure in the driveshaft.
the weak link is the rubber to the road,and the hopping is the change in tire traction.
if there is no hopping,the 4x4 is not working.
Aug 19, 2009 | 2001 Chevrolet Blazer
About the DLP TV you helped with.
Brandon. Locate CN110 on the DMD its a wire plug. Pin 2 is gorund pin 4 is voltage for the color wheel. When the color wheel is off pin 4 should have 5V on it when power is pressed it should have 7v for the color wheel to start. If the voltages on pin 4 is 5V your DM is ok and Color wheel would be indicated as faulty, But if pin 4 is anything less than 5V its the DM which is faulty.
Jun 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
NO Files
update player at rca
Feb 10, 2008 | RCA H100 MP3 Player
System starting problem
The led on the motherboard is a voltage indicator on the +5v power wires from the atx power cable (the large group of wires that enter in your motherboard). Even if the power source is broken and can't supply larger 12V tensions, or other smaller values that +5V tension will be most likely still present. The fact that the led is on doesn't tell us much. You should try to check the power source. Try replacing it at least just for some testing. Normaly this should solve the problem. However if this doesn't work please provide a reply and we will try other solutions.
Good luck.
Jan 17, 2008 | ASUS P5PE-VM Motherboard
How to test power supply
Test the power supply to ensure that it is turned on and that it releases its reset signal.
Good Luck ! Please dont for get to Vote/Thank You.
Dec 16, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Sony TV 27" KV-27V36
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician. i cannot tell you the cost to fix your tv coz my location is in the Philippines.
Jan 18, 2007 | Sony KV-27V36 27" TV
Guillemot Force Feedback Ferrari Racing Wheel (2969046) Wheel And Pedals Set Logo
52 people viewed this question
Top Guillemot Video Game Consoles & Games Experts
shaun taylor
Chris Larocque
Michael Vincent Cruz
Are you a Guillemot Video Game Console and Game Expert? Answer questions, earn points and help others
