During my trip home for Christmas, the small silver button on the top right (the one used to take pictures) popped off. I have the silver button and a small spring that was underneath it... but they will not go back into place and stay. I got the camera in August from Best Buy and they have a 14 day policy - told me to contact Sony.
-   I had the same problem and i fixed it with a local vendor.
Now what is happening is i am able to take pictures without any issues. But there is no half-way-down press now. A single press down will get you the picture. But in the user manual it is said that we should not do a full press. Always we have to use a half-press. Is there any issues if i am unable to do the half-press? Please respond.
-   sunilkumarpv
Sep 23, 2008
-   I have a Sony Cybershot DSC-H2 and my shutter button came off too. I don't know how to fix it or where to get it fixed. when it came off i kind of just stuck it in there and it sort of worked but it kept falling off. but then when i tried it again i think somehow the inside what ever the button is pressing on got stuck b.c now it won't click and take a picture. and i didn't find a spring that came out. it was just the button. what should i do?!!!
-   The button I take pictures with came off. I am using a toothpick now to take pictures. I really need to get this fixed. Please help!-   Guest
Jun 18, 2008
-   My button came a couple of months ago, but I didn't have the spring, was able to use it for awhile by holding the button on, but that eventually quit working then I lost the button. Seems it will be cheaper to by a different camera, certainly not another Sony after learning many have had the same problem.-   Guest
May 11, 2008
-   I had the same problem 2 days ago. Have had my DSC-H2 for 13 months-1 month past the end of my Sony warranty. How convenient. I have the button and the spring. The parts will not just snap back on. I did fina a replacement part at Sears replacement parts online but have not called to order yet. It's sad that Sony wants $181 to fix a problem that may cost at best $5 for the plastic button and spring!-   Guest
There's a more detailed description on how to replace this on DSC-H1 section of this website. The replacement part and procedure, is basically, if not, the same. Just use care and caution!
The release Assy # has been changed to X21083252 for the Shutter button replacement. Sony has the price currently listed at $18.61. No mention is made as to whether "how-to repair" instructions are included.
you should contact Sony. The technical solution for above mentioned problem is the replacement of Release Assy, part number X21083251.
Best regards, Arpad
Was this helpful?
Yes
No
Solution #4
posted on Apr 07, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
mine also came off, and i used a screw from my computer (the ones that hold the chassis together) and i've just pushed it in and twisted it a bit. it still didn't come off and works splendid.
hello, a friend of mine has give to me this camera ,with this problem. I have fix it very ease ,by putting a litle bit of glue on two pieces . the shutter button was workig again like the first time but it came a new problem: the camera w'ont to turn on. when i push the power button the green led is lit, the red led is lit(??) and i heard a short bip and that"s all. Can anyone help me??
Was this helpful?
Yes
No
Solution #7
posted on Jun 05, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi, Is it an involved process to replace this part - the shutter switch in the DSC-H2? Is it replaced from outside just by removing the piece of plastic cover around it or the camera has to come apart fully starting from behind (total dis-assembly) as shown in the repair manual? I guess and hope it is a simple procedure replacing the button. Please respond.
Popular Solutions for Sony Cyber-shot DSC-H2 Digital
when i try to take a pic the orange light comes on then gos off might take a pic might not what do i...
(More)
when i try to take a pic the orange light comes on then gos off might take a pic might not what do i change to make it wirk right
I only can turn on my camera if I start it directly into the Playback mode, if I either press the...
(More)
I only can turn on my camera if I start it directly into the Playback mode, if I either press the shutter, press the playback mode button again to change to capture mode or move the Mode Dial it turns off.
I have the same problem. The shuttter button came off. I called Sony and they wante $181 to fix it. Said that there was not a recall, but there should be!! I had a problem with a Cannon video camera, found out about it and they repaired it for free. Obviously, Sony knows about this and is choosing to not sevice a defective camera. I can say that Canon did support their product so I will think twice about buying a Sony product.
I had the same problem last night...but I have taken more than 20,000 photos with my DSC-H2, it's a year and a half old...I didn't drop ir or shake it, it just popped of...I found the silver button but not the spring... =o(
The silver button came off, but I did not see a spring. (I was not actually there when it happened; this camera is used by my Journalism students for the school paper.)
Could surely use some advice that saved a repair bill, since it would come out of our line item from ad sales, bake sales, etc. (If you feel the urge to pull out a very small violin . . . go right ahead . . . ) Thanks----Ted
i too have the exact same problem...have got my camera, with the button and spring separated from the cam....i tried to put the spring and the button(that i use to press for taking the pic) it din't fit in !! don't know what to do
