Question about Samsung DVD-S224 DVD Player
Door will not open
Our player says DL-on, we are presuming that this means door locked! the player will not turn on or off with the remote or the machine we have to unplug it. Do you know what is wrong our rental dvd is due back asap!!! Help!!!We have tried every which way we can on the remote control but to no avail.
While Unit is ON
press and Hold STOP on front panel, press power on the remote - Toggles
Dealer Lock ON/OFF (This is used to prevent customers removing a sample CD
from a display model
Posted on Jan 12, 2008
Peugeot 508 RXH: I cannot lock the car with the remote. The doors lock, but unlock again. The car detects open doors correctly. I can lock the doors with the dashboard button.
If you have 2 remotes does it do the same thing with both of them?
I/We have a Honda FRV and if you set the alarm from outside the car ....which locks the doors ...and the doors are opened from the inside, (yes I have set the alarm whilst still in the car,) this unlocks the doors as the drivers door has the master central locking switch on it. If I close the door withing a few seconds the alarm reactivates itself and the doors relock automatically
Presumably when your doors unlock the alarm is disarmed? Maybe your issue is linked to the receiver in the security system?
There is a difference, presumably, between you locking the doors from the dash as opposed to doing it from the remote control, the security system is not armed in the former, only the doors are locked +
GOOD LUCK
Jul 19, 2015 | Peugeot Cars & Trucks
2000 cadillac deville driver side won't open with the key
1) Key turns but dose not unlock door. This means that the rod that goes to the back of the lock has came off. This also means that is the reason door is not unlocking with the remote as it pops the lock rod inside the door which pushes the lock open.
2) Key does not turn lock at all but works passengers side door. This means that the locks has been changed in the door, but that doesn't sound like the problem as you say the remote doesn't open the drivers side door so more than likely the rod has came off the back of the lock
Nov 07, 2012 | Cars & Trucks
F'dL what does is mean
This ia a Door Lock Error and it occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Jul 02, 2012 | Whirlpool Washing Machines
What does F DL means i opened the door to add something then t came up F DL and wont start again, the cycle had just started I pressed cancel all it does is beep and flash F DL
Hello and welcome to FixYa
FDL is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Sep 14, 2011 | Whirlpool GHW9400 Duet Washer
Trying to start washer...express wash....code dl f came up.. what is that? how can I fix it.
I'm presuming that 'dl' stands for 'door lock' fault.
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 05, 2011 | Kenmore Elite 45986 Front Load Washer
What does dl mean
DL on this model means door lock it will try to lock 6 times before the fault code will activate.
possibilities to check are
door lock mechanism broke
check door lock /switch assembly for foreign objest
check the wire harness connections to the door lock /switch assembly and at the ccu(main control board)
and last you just have a bad door lock/switch assembly
whirlppol servicer 18 years hope this helps you out could be something simple as door switch jammed or loose .most likely have a bad door lock assembly that needs replaced...
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
Oct 03, 2010 | Whirlpool GHW9400 Duet Washer
What does f dl mean
Hello, F DL means
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
• Door Lock/Switch Assembly Failure
Ohm out the door lock solenoid and the door lock switches. This is most conveniently done at the central control board--use the wiring diagram/tech sheet to locate the proper pins to test from. Unplug the washer before starting work.
Thanks
May 19, 2010 | Washing Machines
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Samsung DVD-S224 DVD Player Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
