Question about Sony DVP-CX995V Multi-disc DVD Player
Dont know how to change dvd with out useing skip botton
How do I change dvd with remote without the skip button? how do I just press number I want and it play?
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    do u have the manual?can email it to u if u want?
    Problem Solver:
  • 3 Answers
Press the Display button located in the middle right of the remote. This brings up a menu on the tv that shows the dvd number. Press the right arrow button to get to the number. You can then enter the number of the dvd you want. After you have entered the number press the enter button. This will cause the desired dvd to load. You press the Display button again to tun off the menu.
Posted on Dec 26, 2008
How to play dvd
If you are using the built-in DVD tray, press TV (in case you have a Cable Set-top box). Then press Input and navigate with the up/down keys to the line labeled DVD. Then press OK. Finally press play on the Polaroid TDA-03211C remote or on the side of the TV. The remote play button is in the center of the row below the row with skip reverse and skip forward buttons.
If you are using a different DVD player, press the input button and then the up/down arrows to get to the input for your DVD player. Then press the DVD button to control the DVD player.
If you are using a universal remote control, then you may need to program it to the TV and the DVD player separately. (Some universal remotes may only support the TV functions of this TV.) Make sure that your universal remote has an input button that works. You may need to try multiple codes for Polaroid TVs.
I hope this helps.
(note: the DVD must be correctly installed so that the printed side (label) is facing the front of the TV. If you do not get a response, try the disc in another DVD player. The DVD player laser tracking can fail without warning. If the disc plays in other units, this may be the problem.)
Mar 02, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
Tip
Comcast Xfinity DVR motorola DCX3400 series want to skip forward 30 seconds?
If you are like me who used to have the satalite DVR you miss the skip forward function that some of the remotes have. With comcast or Xfinity remotes you can program them. Mine says Xfinity on the bottom and since I have no others to compare it to I cant say this will work on all remotes. Watch for the blinks as they will signify that everything is OK. If they dont give it a minute or two and then start over again pressing the buttons fully down. Since most of the button funtions are already taken, and at least on my NEW TV it didnt come with Picture In Picture funtion so these buttons are not being used by me. So lets use that last PIP minus button for this example. When you are done you can still reassign the Aux button back to say a DVD player or something, but only if it doesnt still work. This sequence just programs the remote PiP button.
Press the Aux button one time
Press and hold the Setup button until the Aux blinks 2 times
after it does enter these numbers 01376,
now the remote should blink 2 times again.
press and hold Setup again until 2 blinks
now press 994
and press the Aux button
Press the Setup one time and now enter the numbers 00173
Press the Cable button
Press the PIP Channel Minus at the bottom of the comcast remote and you will see the lights blink again at the top of the remote to signify 2 blinks that it is done.
on Mar 02, 2011 | Televison & Video
Want all region code for Sony theatre player DAV-X1G
it's possible to unlock with a remote control.I Used a "One-For-All" remote.
This process is working on more that this Sony DVD players.
First prepare the remote control to use right device code.
1: Select the DVD button on the remote
2: Hold "Magic/Set" button util the LED blinks twice (Rabbit appears)
3: Press numbers 0533
Now program the remote control to send special codes on button 1 to 5.
1: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
2: Press numbers 994
3: Press "Magic/Set" button once
4: Press number 1891
5: Wait some time
6: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
7: Press numbers 994
8: Press "Magic/Set" button once
9: Press number 2552
10: Wait some time
11: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
12: Press numbers 994
13: Press "Magic/Set" button once
14: Press number 0953
15: Wait some time
16: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
17: Press numbers 994
18: Press "Magic/Set" button once
19: Press number 2214
20: Wait some time
21: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
22: Press numbers 994
23: Press "Magic/Set" button once
24: Press number 0795
25: Wait some time
Now the remote is ready for use on the DAV-X1
1: Start the DVD without any DVD in it.
2: At the same time press and hold "Eject" and "Stop" in and then press "volume +" to get into the service menu
3: Now use your programmed remote
4: Press button 12345 with a small pause between each num.
5: Press button 12345 with a small pause between each num.
6: Wait some time
6: Press button 12345 with a small pause between each num.
7: Now use your orginal remote and turn the DVD off
Tested to play Region 2 and Region 1 DVDs without any problems after this. (The remote i used was a Cameleon 6)
May 13, 2011 | Audio Players & Recorders
How to get unit to play without remote
You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
Apr 22, 2011 | Panasonic Televison & Video
How to play a blu ray DVD without a remote
In order to play a bluray video disc without a remote, it must skip the menu and automatically play the video. The only way to accomplish this is to burn the disc this way, or it must come like this from the factory, and in most cases it doesn't.
The alternative is to press the play button on top of the disc player. Hope this helps!
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 20, 2011 | Samsung BD-P3600 Blu-Ray Player
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Mar 13, 2010 | Philips Televison & Video
Dont know how to set clock
hold sel for a few seconds then search threw using yer skip up and skip down button. untill u hit clock H then use yer volume botton to change.... then hi yer skip up again untill u hit clock M and use yer volume again. then hit sel to finish.
Nov 19, 2009 | JVC KD-G140 Car CD Player
Can you tell me how to decode a grunkel dvd player to all regions?
Model 20-NT
1. Using the remote control, key in the following: Setup, Stop, Skip Backwards, Skip Forwards.
2. You should then be able to change region and remove MacroVision.
Turn on the DVD player without DVD inserted. Then, using the remote control, press this buttons: Setup, Stop, Skip Backwards, Skip Forwards.
Model 22NG
Turn on your player
Open the tray
Press 8 4 2 1 on the remote control --> "Region 2" appears on the TV screen
Press SELECT until 9 for region free & MacroVision free
Model 32S
Press Setup
press Volume +
Press Volume -
Press the right arrow until the screen on the player reads 255
Press setup to exit and all done
Nov 17, 2009 | Televison & Video
Panasonic DMR-EX77 - Error code DVD3
Pan use a version of Linux on the recorder. If you change the hard drive there is a format command in setup to format a new hard drive. Put a DVD in and try selecting and playing both DVD and HHD via the front panel buttons. Sometimes you can get error codes on a unit when the batteries in the remote are low. Try changing them Sometimes the remotes are faulty and not communicating properly. A fix in some cases is to press the number button corresponding to the number shown on the display together with the enter or OK button for at least 2 seconds. Good luck
Jan 21, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Sony DVP-CX995V Multi-disc DVD Player Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
