Question about Nokia 6300 Cellular Phone
When i connect nokia6300 using a data cable computer says that device not recognized" please suggest a solution. I had used standard usb cable, the driver is properly installed. Recently this problem started when i tried to connect nokia pc suite via cable.
  • 365 Answers
This may due to the problem with your data cable or it may occur for some pc's.try to check it with other cable or try to use it on other pc .thank you
Posted on Nov 22, 2008
How can i play videos from a USB with a Kenwood DDX715WBT i tried MPEG-2, WMV, DIVX, AVI, but it doesnt play it shows Unsupported File.
These excerpts from the user's manual....
USB
Connecting a USB device
You can connect a USB mass storage class device
such as a USB memory, Digital Audio Player etc. to
the unit.
• For details about connecting USB devices, see
page 70 .
• You cannot connect a computer or portable HDD
to the USB input terminal.
• For playable file types and notes on using USB
devices, see page 75.
When a USB device is connected...
The source changes to
"USB"
and playback starts.
• All tracks in the USB device will be played
repeatedly until you change the source.
[PAGE 75]
USB playback
Playable files on a USB device
• This unit can play the following types of files
stored in a USB mass storage class device.
- JPEG/BMP/PNG/MPEG1/MPEG2/MP3/WMA/
WAV/AAC/FLAC/H.264/WMV (VC-1)
• This unit can recognize a total of 5 000 files and
250 folders (a maximum of 999 files per folder).
• Make sure all important data has been backed up
to avoid losing the data.
Notes on using a USB device:
• This unit may not play back files in a USB device
properly when using a USB extension cable.
• USB devices equipped with special functions such
as data security functions cannot be used with the
unit.
• Do not use a USB device with 2 or more partitions.
• Depending on the shape of the USB devices and
connection ports, some USB devices may not be
attached properly or the connection might be
loose.
• This unit may not recognize a memory card
inserted into the USB card reader.
• When connecting with a USB cable, use the USB
2.0 cable.
The maximum number of characters (when the characters are 1 byte):
- Folder names: 128 characters
- File names: 128 characters
• Avoid using the USB device if it might affect
driving safety.
• Do not pull out and connect the USB device
repeatedly while "Reading" is shown on the
screen.
• Electrostatic shock at connecting a USB device
may cause abnormal playback of the device. In this
case, disconnect the USB device then reset this
unit and the USB device.
• Operation and power supply may not work as
intended for some USB devices.
• Do not leave a USB device in the car, or expose to
direct sunlight or high temperatures to prevent
deformation or damage to the device
Feb 12, 2016 | Kenwood Audio Players & Recorders
Imation 1TB USB external Hard Drive .....unrecognized in Windows Both in windows7 and XP.
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
Jan 07, 2013 | Imation 1TB Cartridge (IMN27957) Hard...
Trying to copy photos to a folder using Microsoft Scanner & Camera Wizard. Camara is on and is connected to my PC with a USB cable, but the computer can not detect the camara.
First, check both ends of the USB cable to be sure that the ports and the plugs are properly seated so that the metal pins are able to transfer data. Restart Windows with the cables plugged in, and the camera should be recognized. You also MUST have the camera turned ON in order for the computer to read the fact that it is connected. If these suggestions fail, check your Microsoft Computer Management program to be sure that PlugnPlay devices are automatically recognized by your system.
Have fun with your photography!
Sciencewoman
Mar 31, 2011 | Samsung SL202 Digital Camera
I have a JVC KD-AHD79 stereo. I tried plugging my Samsung Fascinate phone into the USB port to use the music on the memory card but it either says "cannot play" or gets stuck on...
This unit is able to take I Pod and I Phone. If unable to connect your particular phone/device via bluetooth please note the following?
• Make sure all important data has been backed up. • You cannot connect a computer or portable HDD to the USB input terminal of the unit. • Avoid using the USB device if it might hinder your safety driving. • Electrostatic shock at connecting a USB device may cause abnormal playback of the device. In this case, disconnect the USB device then reset this unit and the USB device. • Do not leave a USB device in the car, expose to direct sunlight, or high temperature to avoid deformation or cause damages to the device. • This unit may not play back files in a USB device properly when using a USB extension cord. • USB devices equipped with special functions such as data security functions cannot be used with the unit. • When connecting a USB cable, use the USB 2.0 cable. • Do not use a USB device with 2 or more partitions. • Depending on the shape of the USB devices and connection ports, some USB devices may not be attached properly or the connection might be loose. • This unit cannot recognize a USB device whose rating is other than 5 V and exceeds 500 mA. • Do not pull out and attach the USB device repeatedly while "READING" is shown on the display. • This unit may not recognize a memory card inserted into the USB card reader. • Connect only one USB device to the unit at a time. Do not use a USB hub. • Operation and power supply may not work as intended for some USB devices. • The maximum number of characters for: - Folder names : 63 characters - File names : 63 characters - MP3 Tag : 60 characters - WMA Tag : 60 characters • This unit can recognize a total of 65 025 files, 255 folders (255 files per folder including folder without unsupported files), and of 8 hierarchies.
Good luck with it.
Mar 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
I installed the PC Suite for my LG BL40, but it won't connect via USB and my computer doesn't have a bluetooth device. |Ive tried everything suggested and when I connect choosing Music Sync, it connects bu...
First, syncing is the transfer of data between computer software's that are designed to acquire and share with another entity. The sync function usually is embedded in the computer program. Once the computer recognizes compatible software that has several capabilities including transferring data, a USB connection capacity should be achievable. Usually devices that are designed for data transferability should be capable of acquiring a USB connection either as physical cables or wireless Bluetooth technology. The power to sync is contained in the software program. Once software that has sync capabilities is installed on the computer, any USB cable that is attached to an empty port would display a user message asking for further procedures. For example, USB connections on the computer that has media software's would display device recognizes link requiring data transfer. The solution lies in the software that is relied on for sync capabilities. Acquire Windows Media player, Real One player, or ITunes player as downloadable onto the computer to achieve compatibility.
Important Notes
USB ports are available on all computers as versatile connection links to devices that would require communications. The computers original systems are expected to recognize USB cable connection as manufacturers default. Usually, the computer is likely capable of upgrading several software programs that would least communicate with the USB. For example, the program suit installed has compatibility requirements to perform on the computer as an entity. Also, the program suit requires compatibility with USB connection for another device that would be connected to the computer. Attempt to install media transfer programs that are designed with sync features.
Jan 26, 2011 | Computers & Internet
Garmin navi will not connect to computor so i can register
You may need to replace the usb cable that you are using to connect this device to your computer.
There's just 4 steps on how to connect garmin navi to computer.
1. Connect the mini-USB end of your USB cable to the back of the Navi.
2.
Turn on your PC and connect the standard USB end of your USB cable to the USB port on your personal computer
3.Power on the Navi and give the computer time to recognize the device.
4.Click "Start," then "Computer." The Navi hard drive should be among those listed under "Devices with removable storage." You can click on the Navi's drive icon to access your Garmin device
Dec 26, 2010 | Garmin nuvi 255W GPS Receiver
My usb device is not working,I have pluged in one computer saves some data and connected to other computer ,it is not detecting.It has giving the following error message''attached usb devices is...
this is because the usb device data storage capability has lost...try inserting into the computer in which it worked fine and format it using FAT32 or NTFS format....the allocation should be "default allocation" while formatting....try this it might help....
Mar 29, 2010 | Computers & Internet
Ti connect doesn't find it.
If you use the TI USB Silver Link cable there should not be any problem. In case of problems, download the latest TI connect software and install it anew.
But if you use the mini UsB to Standard USB Direct cable you will have to install manually the correct drivers.
Here is a copy of a post I wrote to answrer that question.
If you have a USB SilverLink cable, use it to connect the calculator though the I/O (round) port.
If you do not have a USB SilverLink cable, you can use the mini USB to USB Direct cable but you will have to install the correct driver for it.
I do not know what computer operating system you are running and I use Windows XP so I will describe the installation procedure for Windows XP SP3.
Install TI connect 1.6 for Windows; if your system is Vista you must install a patch available on the TI website, at the same page where you find TI Connect.
After you install TI Connect, connect you calculator to the computer with the mini USB standard USB Direct cable. Windows will detect the calculator and will try to install the drivers. You will have something that is similar to what is on the three screen captures I am inserting in the post. On the last screen, choose the TI Educational Handheld device and click next.
When Windows asks to stop installation, click continue anyway
After the installation, click finish.
Device manager will show you something like what is on next screen (TI Educational Handheld device)
Run TI Connect to verify that the calculator is recognized. Connect your computer to the Internet and click the Updates Button on the TI Connect tool bar.
Jan 17, 2010 | Texas Instruments TI-84 Plus Silver...
Where do I connect my camera cabel to my computer?
Some cameras have a multi-use cable which can be used for both data transfer or copy, and video output. Most cameras I have worked with usually have two cables, one for video playback and the other for data transfer or copy to a computer or other device. Most all cameras today use the convince of the standard computer USB access.
Most cameras have a cover made of either rubber or plastic which can be folded back to reveal connectors for mini-USB and video outlets. The appropriate cables must be used to connect to video or a computer or other device.
It is advisable to read your user manual for information on usage of the video and the data transfer cables and the software, if that is what you need.
I also suggest to skip all that and use a card reader, no more hassle. A card reader will give you more freedom without having to install software to see your photos or other files.
Nov 08, 2009 | Canon PowerShot A570 IS Digital Camera
Computer doesn't recognize Zen Vision:M
just connect it using another USB data cable
it ll surely work
tc
Nov 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Nokia 6300 Cellular Phone Logo
159 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
