No masterplug tvrc4n TV remote code for SAMSUNG TV/VCR combi
I have tried all programming options and manual listed codes on the TVRC4N and the TV will not respond
The TV model is TI-14N53x
Are there any other codes or procedures that I could try?
  • nicolemarieh Nov 22, 2008
    I cannot use it either - checking online this may be because the original Samsung remote has a function for tuning and apparently this prevents some universal tv remotes from working.  I'm not sure if that's true, but I am giving up and buying a replacement remote !!
3 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Programming Codes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • 166 Answers
SOURCE: Universal remote TVRC4N missing code
If you read your instruction booklet you will find a section for code unknown, or try thomson codes Ferguson have been made by Thomson for 15 years plus.
Posted on Jun 02, 2008
Does not provide code for my pacific dvd player
You can perform a manual search.
Press and hold TV,SAT,DVD or VCR until the centre light blinks red.
While it is blinking press 0000
The flashing will speed up.
Press the power button repeatedly - it will cycle through all codes.
When your device turns off (powers off) press the okay button.
It should now power on and off correctly.
Check the other buttons to see if everything works.
If it does not start the process again - it will hit another code which will also power down the device - takes a long time but should work - manual states it may take 20 mins - practise says longer!
May 16, 2009 | Pacific Digital PRIMEVIEW801 Video...
Lost a book
Samsung Codes for Masterplug 4 in1 TVRC4N remote:
1050
1074
1089
1102
1103
1109
1113
1176
1221
1223
1224
1225
1239
1281
1286
1287
1288
1289
1290
1291
1292
1293
1294
1295
1337
1369
1381
1385
1388
1389
1390
1393
1402
1408
1410
Oct 24, 2008 | Philips Magnavox Learning Universal Remote
Masterplug tvrc4n 4 in 1 remote control/sanyo
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 23, 2008 | Philips Magnavox Learning Universal Remote
Masterplug tvr c4n remote(universal)
Try these simple trick to find out your remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the TV.
Jul 13, 2008 | Philips Magnavox Learning Universal Remote
May 31, 2008 | Televison & Video
Programming Codes
Hope that helps!
IrishDruid
Apr 27, 2008 | Televison & Video
Hi the codes for hitachi are 0074,0082,0081,0511,0201,0616,0234,0236,0255,0232,0554,0110,0537,0075,0594,0147,0216,0143,0550,0518 turn on tv, 1.press tv button on the remote 2. press setup button until it flashes twice enter code then turn off by power button (keep repeating 1-3 until tv goes off) hope this helps.
Samsung vcr 0278 or 0455 as above. Angela.x.
Feb 22, 2008 | Philips Magnavox Learning Universal Remote
Programming Codes
hello cant you help me
i have a dvd recorder Model is DMTECH DVD-400RW
i have note code
if you have it cant you send it to me ond this mail
04273105@telia.com
Mvh Micke
Jan 01, 2008 | Televison & Video
Televison & Video Logo
315 people viewed this question
Top Televison & Video Experts
