Question about Belling BIM60 Microwave Oven
Change the bulb
I need to change the bulb on a Belling Cobi micrwave but dont know how to
  • Belling Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 26, 2008
  • lucia65
    lucia65 Jul 13, 2012
    Is the bulb a screw in one or click and turn? I can not get it out, it is firmly stuck and appears rusted at the bottom. Any suggestions?
  • lucia65
How do I replace bulb in belling m385 tcs
any I have looked at the entire shell has to be removed
Feb 24, 2015 | Belling Microwave Ovens
Bulb replacement model BEL/CJS21
You need to take the 5 screws out on the back and side oc the cover - 2 are a special screw head but if you jam a small flathead screwdriver in you can snap off the tiny stud so that you can now use a star driver. (be prepared to damage the screwdriver head). The bulb can be seen in the black plastic assembly surrounded by wires. You can just about unscrew the bulb with 2 little fingers - hey presto squeeze new build in and pug covet back on
Jan 24, 2010 | Belling Microwave Ovens
Changing the interior lightbulb of Maytag #MMV5207BCW over the range microwave? How the #$!% do you get the cover off to change the bulb?
I have a belling combi microwave, the covection oven works well but the microwave oven has stopped heating the food up and also the defrost isn't working ? Any tips or does it need repairing and wat are the costs?
Nov 24, 2009 | Maytag Appliances Over-the-Range Microwave...
Belling GJS20 - light blown, how do I change it? Thanks!
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 17, 2008 | Microwave Ovens
How do you take the light bulb out of this micrwave?????
First be sure to unplug the oven or open the circuit breaker.
Some bulbs are screw-in and some need to be pushed in slightly, then turned counter-clockwise.
Sometimes they get a little food grease or oxidation between the threads of the lamp and the socket.
You just have to be persistent. A slow but steady pressure is best, because too much pressure can break the bulb off in the socket.
While that then makes it easier to use pliers, there is the risk of a nasty cut. Gloves might help if it's really tight, or maybe a small piece of rubber strip to improve grip.
Before installing the new bulb, I recommend a thin layer of lubricant (WD-40, Vaseline, etc) to help prevent seizing in the future.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Jan 02, 2008 | Maytag MMV5186A Microwave Oven
BULB NOT WORKING ON MY KENWOOD GRILL/MICROWAVE GJ/SS25
First unplug microwave. Check to see if there is a cover in front of the bulb that can be removed with a screwdriver normally philips. If not, you must remove the entire top cover for access to the bulb housing.You will have to remove side screws if any, and just the rear screws that hold the top cover on, remember you may find that some if not all may be torc screws.In this case you will need the correct tool.Usually a T20 tamper driver.After you remove the top cover you can find where the bulb cover is and replace the bulb.CAUTION:ALWAYS BE CAREFUL TO KEEP HANDS AWAY FORM THE HIGH VOLTAGE SECTION. Sometimes the high voltage capacitor will not discharge on its own and will retain voltage plugged in or not.
Nov 01, 2007 | Microwave Ovens
Micrwave starts but then quits
Microwaves should only be worked on by fully qualified repair people and my advice to you would be to bring it to such a person,they can be dangerous to work on due to the presence of such high voltage, other than changing a light bulb any other repairs are out of limit.
Jul 19, 2007 | GE JVM1441 Microwave Oven
Belling Microwave Problem
Apparently this one has a mechanical timer. That lack of electronic controls does lessen the complexity. I don't know about the specific regulations concerning British / EU microwaves, but I'm sure there's a fuse inside. In most cases, just replacing a blown fuse will not be the cure, unless one finds the reason it blew. What made it fail (if it did) is the real question. Loose fuse holder allowed excess heat? Shorted component or wiring? Or, is there a failure in the mechanical timer that's causing an open circuit connection? That can certainly happen. Also, a door switch may have failed. This is most commonly caused by opening the door while it's cooking, instead of turning the oven off first. I would suggest you contact Belling service: http://www.belling.co.uk//CMPage.aspx?pageid=130&subsectionid=85§ion=ContactBelling Good luck.
Oct 11, 2006 | Belling BIM60 Microwave Oven
Belling BIM60 Microwave Oven Logo
442 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
