No communication between printer and cumputer
Got cumputer checked out no problem there It copys
alright try other conection no luck
  • 4,472 Answers
First off what is the make and model of the printer. What operating system are you running? Once I have more information I can assist you appropriately.
Thank you,
Lee
Posted on Nov 23, 2008
  • 13,433 Answers
Try the printer on another computer if possible and see if it works there, do you have the drivers and software installed? can you tell us the brand and model of the printer.
does the computer detect the printer? do you get a ding dong sound when you connect and power it on?
  • 19,396 Answers
Before connecting the printer you need to install printer driver software, let us know make and model of your printer.
No communication between printer and computer.
try going into the control panel and add the printer again as the new os may not recognize it
normally unless you set it again the os has a microsoft printer as default unless you reset it to your printer
Sep 02, 2015 | Epson WorkForce 600 All-In-One InkJet...
I have a scanner Canon MP270. I have used it successfully before. Now I get a message on screen: Cannot communicate with screen. Cable my be disconnected or scanner may be turned off'. I have chec
First, please check all USB cable connections, unplug and re-plug the cable both at computer side-port and printer side-port.. Then,check if USB cable is good. If you are sure that's all alright so the logic board of the printer may be faulty. Overall this is about connection problem. Good luck.
More solution about printer at:Printer Clinic
OR
Download Service Manual
Sep 23, 2012 | Canon Pixma MP270 All-in-One InkJet...
Communication error !! check all conections and make sure all device blablabla.....
check your communication cable. usb cable or parallel port. Replace the cable and try again.
If still not working then may be the main board has got problem.
Mar 11, 2011 | Epson PLQ-20 Matrix Printer
Ricoh Aficio 450 back side is dirty?
Problem on charge roller,Upper drum unite,please clean or change it then solve your problem.
With the best luck.
Jan 20, 2010 | Ricoh Aficio 450 Copier
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
I want to install Norton antivirus..
First Run the Norton Removal Tool and then try to install It
Mar 31, 2009 | Webroot AntiVirus with AntiSpyware &...
My hp psc 2410 photosmart printer will not print - only copy
Check to make sure your PSC 2410 is in fact the default printer. If it is, make sure your cable is firmly plugged in to your printer and CPU. Clear the print queue. Turn off and restart printer. I have found that your problem is basically a communication problem between the computer and printer. Also check www.hp.com. Good luck.
Feb 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Sep 11, 2008 | Canon imageRUNNER 400S Copier
Toshiba e-studio 45
did you fing the problem???
Aug 12, 2008 | Office Equipment & Supplies
HP PSC 2410 very slow printing issue
It is a cartridge problem. Solution for my hp 3645 (I have the same story as bb18, but different printer) was to remove color cartridge!
The printer is fast now, of course it does not print in color :) (I`m waiting for a new color cartridge) Good luck,
Marcin
Dec 26, 2007 | HP PSC 2410 All-In-One InkJet Printer
jasbo
jasbo
