Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Intermitent no sound on digital, KDL26S4000 sony bravia TV
Every so often the sound on my TV goes on digital tv only, the sound on the analog transmission is OK, it's usually happens when pressing the favorite button to change channel, to fix it i turn the TV off and then on, it's a brand new TV, and it's a replacement TV as the first one had the same problem.
  • 2 more comments
  • dorong50 Nov 27, 2008
    I received a reply from "Selvol" and I'm trying it for the last 3 days and so far i works, but as the problem was intermittent I would like to wait a little longer before rating the answer.
    thanks
    dorong
  • dorong50 Nov 30, 2008
    Well, last night while changing the channel the sound went off AGAIN, this time I turn the intelligent sound OFF i suppose it's the "steady sound" that Selvol was talking about, so will see if that fix it.
  • dorong50 Dec 02, 2008
    sony says that the problem is with the digital tuner, and they gave me a new TV, will see what happens.
  • Anonymous Dec 18, 2008
    i have a same problem, but sollution #1 does not work. Do you have another idea? I have kdl32w4000 new television
    Scholar:
  • 115 Answers
Try going in the settings and turning off "Steady sound". Or turn the audio setting to stereo, disable surround sound.
Steady Sound
You don't have to listen to commercials at a higher volume than the normal programming. This TV has a volume equalization feature for both program and commercials to enhance your audio entertainment.
Selvol
Bravia XBR 42"
Posted on Nov 25, 2008
Hi, I have a sony bravia tv ( klv20G300A) which was bought in Hong Kong about3 years ago . I haven't been able to get it to work with the uk digital signal. I am wondering about it's compatibility-...
This tv has analog tuner and you need digital tuner in tv to get digital signal in UK, alternate way is to hook cable box with this tv that will convert digital signal into AV output that will connect to AV input of tv to get cable channels.
Aug 03, 2011 | Sony BRAVIA KLV20G300 20 in. EDTV-Ready...
I purchased an Sony Bravia LCD 26 inch of KLV S200A series 3 years back. The LCD has now started developing problems like automatically the power goes off when any particular channel is being viewed and...
You have intermitant problems which may be caused by contact resistance or circuit overheating.After it cooled down the tv starts again. Leave TV on standby at all times.
Jan 03, 2011 | Sony BRAVIA KLV26S200 26 in. LCD TV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
Nov 20, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
No sound when in tv/video mode
Do you have it connected with HDMI? If so, run the HDMI directly to the TV and run an optical or digital coaxial to the receiver. That will solve the problem. If that's not the case, go into the receiver's main audio menu and make sure it's set to "auto" or "digital" or "analog" whichever you are running. Hope this helps
Oct 17, 2009 | Sony BRAVIA DAVHDX275 Theater System
No Picture and No Sound on all Analog Channels
Ur tv shouldn't set in cable mode, if u don't have pay cable,or satalite,extra..Should set in air channels.Buy a digital antena or out side roof antena u get all the channels airs.
Aug 19, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Can't get digitall channels
I have the same problem, If anyone could help it would be appreciated.... I have the coaxial cable plugged in which on another TV had all 85 channels, and I changed the TV from analog to digital and reprogrammed it but I still only get like 4 or 5 local channels?
Jul 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Jun 22, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Picture turns off sound is on
Hi Anya, Im sorry to hear of your difficulties but very happy to know im not alone. I have the same exact Sony model and the same exact problem. I wasnt sure if it was my Tv or my upconvert Sansung DVD player. I spoke with Sony assistance..and well..they were of no assistance. They blamed it on my HDMI cable, then the dvd's i was playing, then the dvd player itself. I ruled out all of the above. Mine goes black when i play a dvd in the upconvert format (720p or 1080i) otherwise known as digital..but the analog signal goes through fine. Luckily i am within my 30 days since I bought it, so now that I have seen your posting and am certain its a tv issue, I think i will return it and buy a Samsun tv (a great alternative for same price with only drawback being a glossy screen=not good for bright rooms but amazing color clarity). Sorry I dont have answer for the problem other than your not alone on this one. I have read other Sony users listing similar issues. I hope all goes well with you and wish you the best Matthew
Aug 05, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
261 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
