Question about Lexmark X5250 All-In-One InkJet Printer
Printer installed & ready but wont print
I have a lexmark x5250 (all in one)
everything seems to be plugged up/installed correctly. im running on Vista if that helps....
in the control panel under printers, it show it as installed & default & has the little green check mark. so there seems to be no problem. it copies & scans just fine! it prints the maintenance pages. (like clean nozzles & aligment)
but it wont print the test page! and it will not print anything that i send to it at all! nothing! nothing off the internet! i have microsoft works and it will not print any document from there either.
i select print from the file drop meny & nothing happens... the little printer status icon comes up at the bottom task bar but it says no items pending. and when i click print from the menu the window pops up & everything and it shows the lexmark there and is check with the little green check mark?
i just spend $50 on new ink cartridges! please help me! im a student who needs her printer! why isnt it working?????
thanks in advance!
Found solution: driver software had an error while installing & only installed half the proper software. i had to uninstall the lexmark 5200 serious software completely & download it again from the lexmark website.
i talked to the lexmark customer service live chat line on their website & found out what the problem was. they are very helpful, i highly recommend using it if you have a problem with your lexmark product!
pretty simple solution, its just a little time consuming.
Posted on Nov 23, 2008
Lexmark 5250 won't fax. I have installed everything several times but says something about OCR not working. It will scan & print instead of sending document to Fax. I can open Fax window, but...
Use the Lexmark All-In-One Center application to send faxes from your computer (make sure your computer is connected to a fax modem). From the Creative Tasks section of the All-In-One Main page, click Fax using PC modem. Follow the instructions on the computer screen.
Jul 25, 2011 | Lexmark X5250 All-In-One InkJet Printer
I have a x5250 printer and would like to add it to my partners computer but i have lost the disk
I suggest not to plug the printer to your computer yet. Download and install the driver first. Here's the link to the Lexmark website for the available Lexmark X5250 drivers. http://bit.ly/al9bqi . Choose the right driver compatible with your computer's operating system. Download and install the software. Follow the instructions on the software. Hope this helps.
Jun 18, 2010 | Lexmark X5250 All-In-One InkJet Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X5250 Printer
chech to see if the cartridge slot locks down the tab that locks the cartridge have been known to break. or run a maintenance check and clean the printer heads.
Sep 27, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lost software
I also misplaced my cd to install my x5250 lexmark printer
Aug 29, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lost my cd software
Go to this link and select your windows version that your computer is using and download the software for your printer..
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:437:0:0
Hope that helps...........
Aug 09, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark X5250 PAPER WONT AUTO-FEED
Very pesty!!! Ok, it may be a paper feeder issue. It could be a partially jammed roller or carriage, open up unit as if you were to change cartridge, use a torch to check for the tiniest paper block or foreign material. You would be surprised what can fall or accidenatlly get in them...funny that, i just cleared a tiny piece of toddler debris from my lexmark, and i missed it the first time. Also, paper sensors can start to go and die, hope it is not this!!! as it will need replacing if it is. If it is printing, it may also be too much info from pc to printer. Does it only do this at certain times or all the time? Try clearing the print jobs memory by printing a small document but click on print icon and choose cancel all print jobs. Wait until it does. Try printing again. Also open notepad as if you were to print it, right click on file and print, and check if printer says ready...indicating it is functioning status. this can help diagnose problems sometimes it will give you an error code or message you need.
Aug 11, 2007 | Lexmark X5250 All-In-One InkJet Printer
Lexmark X5250 All-In-One InkJet Printer Logo
185 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
