Question about Hoover Washing Machines
My front-loading Hoover washer/drier (Softwave 1100, Model A8754). Will carry out the wash cycle but not go into spin cycle and thus door will not open. Checked for blockages and none found. Can you help please? Chris
  • Hoover Master
  • 3,463 Answers
Door will not open if it has water in it.
Lay hose down to get rid of water, then you can open door.
Try the spin with no water in, if it spins, then you have a draining problem
Posted on Nov 22, 2008
  • Barry Coates
    Barry Coates Nov 24, 2008
    I am interested to know if you solved your washer problem, and what the solution was. Cheers
Hoover softwave not doing anything except clicking
It sounds like the rotating program controller has failed. It is telling other parts of the machine to do things as part of the wash cycle and the signal is not reaching them. This is an expensive part to replace. Get it fixed under guarantee if its new. If its old replace it, but do not buy a Hoover, they are very cheaply made and fail a lot. If you want a cheap one buy a Zanussi.
Dec 20, 2013 | Hoover HC6 110M Front Load Washer
We have a A8754,A8756 Hoover washer dryer 1100 WS115 washer Dryer 1100 the spin cycle does not work also the door gets locked, currently there are clothes in the machine & the door is locked, could...
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly and good luck!
John C
Apr 10, 2011 | Hoover Nextra 160 HNWF 3137 Front Load...
I have a second hand hoover softwave 1100 washer dryer and there are five click switches on the front. I have worked out that the far right one is the power but what are the others for please?
Hello Librimelow,
The Buttons on the Hoover Softwave are as follows from left to right:
1. ?
2. Half load
3. Wool
4. Low Heat
5. Power
I can not find what the first button is I have looked every where I can think of to find out what the first button is. YouTube has many pictures of the front but you can not make out the first button of the group. Sorry I can not be of more assistance.
Thank you for choosing
Mar 16, 2011 | Washing Machines
Can any body tell me what size the front drum bearing is for a hoover softwave 1100 ,model No A8754 washing machine is ?
You can buy a drum bearing kit on the net or from depending where you are..Some kits are sold as a Half drum with prefitted units quite Expensive......
Feb 10, 2011 | Hoover Washing Machines
Front load GE Adora washer isn't spinning when it should. Other sites I see they talk about replacing the door lock assembly...what else could it be?
I had the same problem with my front load (different model). The pump was not pumping out the water, thus stopping or slowing the spin. Take off your pump (located under the washer in the front right on my model) and look inside to see if there is any junk stopping the plastic spinner to spin. Clean out really good along with the attached hoses. Replace (tricky!) and try the washer! I had lots of junk in the pump along with a few hairpins that stopped the sinner in the pump. This is a tricky process on my model.
Mar 28, 2010 | GE WSXH208A Front Load Washer
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Washing machine problem
I have a performa 1100. No 4 is the 40 degree is the normal cottons cycle which is the one I use. Tip- only fill the drum 3/4 full otherwise it struggles to drain and spin- I know!
Jan 21, 2008 | Hoover PE235 Front Load Washer
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
335 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
