Question about Emerson SpongeBob SquarePants TV
Sponge bob televeision will not work when switched over to av/in to play dvd player
We've had lots of problems with this tv so far and were about to lose it and just go buy a new one...hopefully you can help with this problem and prolong our financial downfall. Wehn trying to switch over to play the dvd player with the av/in button we get no picture and it reads av 1 or av 2 or switches back to the regular channel 2.
You have to use the dvd/tv button on remote to view dvd
Posted on Mar 02, 2007
DVD output to TV not displayed
So you have HDMI off of the PVR into the TV and AV off of the DVD Player into the PVR at the moment? Just for info what connectors do you have at the back of the tv, dvd and pvr? In's and out's...
Feb 28, 2014 | Televison & Video
Sponge bob DVD player will work on a regular TV but will not show up on the sponge bob tv anymore. Also tried a different DVD player and only get a blue screen. Shows AV then AV then tv or something. It is...
Hello
Your Emerson Sponge Bob's model will be SB350. It is a TV/DVD combo, with two AV inputs too. You ahve to see only DVD player with it as you says. You can change its mode to eiter TV/AV or DVD/TV by its remote control buttons. Press the DVD/TV mode button on the remote control to chage the modes to TV or DVD. On DVD mode, you can play DVDs with it. I thinks that you have its user manual with you now. Go to its pate [23] where there is illustrations for which button on the remote control handset should be pressed to select this. If you haven't its user manual with you, send your email address to me by FixYa comment box. I'll send a copy you the user manual to you by return mail. OK.
Jun 27, 2011 | Emerson SpongeBob SquarePants TV
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
Lost sponge bob tv remote control
Get the RCA 4 device universal remote from radio shack. model #RCR4383N $10.00. It wouldn't work using the emerson codes in the manual. Let it find the code automatically. input button on bottom will switch to and from AV input.
Oct 10, 2009 | Emerson SpongeBob SquarePants TV
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Unable to locat and select the AV channel on new LCD HD TV
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
Dec 21, 2007 | Televison & Video
Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Jul 21, 2006 | Emerson SpongeBob SquarePants TV
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
Emerson SpongeBob SquarePants TV Logo
163 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
