Question about HP Computers & Internet
My Vista lap top has been freezing upon start up.I have overcome this problem many times'by removing the battery & then replacing after a short while.After going through the repair cycle i have been able to start up.The battery condition is ok.
  • Ashish Dwivedi
    Ashish Dwivedi May 11, 2010
    Please tell me the last screen you are able to see while booting up.E.g:Screen on which logo appears or login screen.
    Moreover,let me know if you have made any hardware or software changes since the time its not working.
  • Steve Nordquist
    Steve Nordquist May 11, 2010
    Where does it freeze; and are you removing the battery with the AC on, and seeing it just unfreeze and continue, or does it just get past wherever it froze?
    Additionally, to fix it and perhaps get a better diagnosis:
    What model is it, and is the BIOS the most current one?
    Are the HP and video drivers, power management and battery utilities also the most current available?
    Is Vista completely up-to-date with Windows Update as one would expect?
  • 153 Answers
Check if the components are sitted properly, like RAM. And then go to the BIOS and select autodetect the hard disk and boot from Hardisk. Try this.
Posted on Nov 24, 2008
HP Lap top touch pad locked. How to correct please
By now you probably figured out you have to remove the power cord and battery to turn off the laptop. Let it cool down, 30 minutes or so, and then replace the battery and restart the laptop.
Feb 17, 2014 | Computers & Internet
Signal light fuse keeps blowing
the fuse stopped the fire. that is what fuses do.
so, you have a dead short on the blinkers.
remove each lamp 1 at a time.
yes, lamps can short. (twisted too hard)
remove them.
still blow the blinker fuse.?
yes, then the wires are shorted.
and guess what, top reasons are.
1: trailer wiring, look behind each lap assembly, BINGO?
2: hacking or collision, yes, look 1 more time. ,yes behind the lamp assembles, look carefully for DAMAGE.
Aug 05, 2013 | Suzuki Jimny Cars & Trucks
How can I refresh bios from cd rom drive
Remove the battery of laptop and press power button to discharge any charge in motherboard that will reset the bios. Put battery back and press start button and press hold delete button to enter into bios, where you can select optimized setting or fail save mode whatever good options available and boot. If you have windows 7 installed, check your RAM. For instructions use https://www.youtube.com/watch?v=GJsVvHJqO34
This link helps improve browsing skills.
https://www.youtube.com/watch?v=9C3SRvhUMwY
Dec 13, 2017 | Lenovo Y550 (4186-58U) PC Notebook
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
How long does battery last
It depends upon the Amp/Hr rating and the age of the battery.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
If the battery appears to be fully or nearly fully charged and you remove the power adapter and if discharges to flat in a short time then the battery is worn out and needs to be replaced.
Dec 29, 2009 | Acer Aspire 3050-1733 Notebook
Lap top freeze when trying to put it off.
are you replacing the battery properly and does it come on with
AC power jack
Jan 23, 2009 | Acer Aspire 3680 Laptop
Lap works but the battery does not charge
oh
maybe your power IC is broken
or something about your power connection
you said The lap top is less than 12 months old,
it's mean it still has it's warranty
if you lost your warranty card
don't afraid
if seal(s) above your laptop is not broken
you still have your warranty
Jan 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Gauges cutting out
Check grounds and battery connection check socket at cluster for contact or corrosion MOST LIKELY YOU NEED A NEW CLUSTER
Sep 30, 2008 | 1999 GMC Sonoma
My hard drive got damged and has bean replaced with a new one, I cant get operating system to work more than 30 days. I have installed vista using a reboot disk that came with lap top. The lap top worked...
I AM CURENTLY AWITING ANOTHER REBOOT DISK AS THE MANUFACTUERS OF THE LAP TOP SAID IT MIGHT NEAD THE FULL INSTAL OF VISTA HOME BASIC AND NOT JUST THE REBBOT PROGRAM VERSION I GOT WITH THE PC. AS THIS DOES NOT INCLUDE THE START UP SETINGS THAT CONFIGS THE BIOS TO USE VISTA. ( I DIDNT UNDERSTAND THIS TILL I ACTURLY GOT INTO THE BIOS) THE NEW DISK WILL ASLO INCLUDE A NEW PRODUCT KEY THAT DOES NOT NEAD TO BE CONFIRMD VIA INTERNET TO USE AS IT IS JUST THE BASIC VISTA PROGRAM THAT SHOLD ALOW ME TO INSTAL MY UTILITIS AND DRIVERS TO INSTAL THE MODEMS AND OTHER SYSTEM FILES. WHEN I ORIGANLY GOT THE LAP TOP IN 2007 THE REBOOT &RECOVERY DISKS ONLY HAD THE SET UP PROGRAMS THIS ALOWS YOU TO INSTAL VISTA OPERATING SYSTEM BUT NOT ALL THE PROGRAMS WILL WORK AS YOU NEAD TO DOWNLOAD THE FULL SYSTEM SETINGS. SO JUST TO LET OTHERS KNOW IF YOU GOT A LAP TOP OR PC THAT ONLY HAD A REBOOT DISK TO CHEK THAT IT IS THE FULL VERSION ( NEW VISTA RECOVERY 2008 ) AND NOT THE 2007 ONE
I WIL LET YOU KNOW HOW I DID IT IF THIS WORKS
THANKS FOR THE OFFER
LIL ANDY
Jun 28, 2008 | Computers & Internet
Computer freezes up (Hangs)
On Vista it's not working cuz u don't have propper driver installed for ur printer, as for PC freezing, chek printer's settings in XP, if it's set to print imidiatelly and not spool print jobs first, it could be ur problem.
Jul 23, 2007 | Teac P11/KIT Thermal Printer
Computers & Internet Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
