HP Photosmart all in one. Trouble with Telephone & fax rings
Hi guys. Have a HP Photosmart 3110 all-in-one. Printer - fax - scanner - copier. I believe that I need to set the phone rings on the fax machine in order for the phone to ring. Incoming calls to the telephone are diverting to the fax machine and I am unable to answer.
Could you please tell me how to set the rings. Are you able to help me please.
Many thanks.
Natalie
    Novelist:
  • 88 Answers
Hi Natalie,
Did you follow the instructions in your HP Photosmart 3110 AIO manual, starting on page 30? I'll assume that you set-up your printer using Case E or Case H, where you share a voice line with your fax service. If so, then you should set the AUTO ANSWER option to OFF per the instructions on page 50.
If you have an answering machine, then you should set up the printer using Case I, whereby you will set the AUTO ANSWER option to ON and then set the the RINGS TO ANSWER to a number greater than the number of rings for your answering machine to pick up.
I hope this helps. If you have another configuration that I haven't answered (i.e. other than Case E, H, or I), please reply back with your exact set-up.
Or if you have lost the manual, you can get it from this website:
http://h10032.www1.hp.com/ctg/Manual/c00485549.pdf
If you found this answer useful, I would appreciate you leaving feedback.
Thanks,
Lee
Posted on Nov 23, 2008
How to repair a fax sensor. I can send faxes but not receive.
What happens when you use your cell-phone to dial the telephone-number of the FAX?
Does the number "ring" in your ear?
Does the display-panel on the HP show "incoming call" or "answering" ?
What happens?
What does not happen?
Feb 17, 2011 | HP Photosmart 3310 Printer
We changed our telephone package last week, eliminating the dedicated fax line to one multi-ring line. The faxes aren't coming through now. Any suggestions?
You will have to set the Multi-ring pattern in the Printer Fax Setup to distinguish between the phone ring and fax ring
Press Setup button
Scroll to Advanced fax setup ( Press OK )
Choose Distinctive Ring Pattern ( DRP )
Set the multi-ring you have been assigned for Fax
Press OK -
Try dialing the no., the Fax should ring
Try sending Fax or Recieving, it should work.
Also, Turn off the ECM
under SETUP - FAX Settings - ECM ( Error correction mode ) - Turn it OFF
Jul 06, 2010 | HP Photosmart C7180 All-In-One InkJet...
Not accessing the tone for fax only keep on ringing
Pick up a telephone handset (or use your cell-phone),
and dial the EXACT same numbers.
Does it ring forever, or does the remote FAX "answer" the call, and then start sending "tones" to your telephone?
Sep 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cannot send or receive faxes
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
FAX LINE NOT RINGING TO TELEPHONE
This is what is called a ring trip.
unplug your fax machine and plug in a normal phone. call the fax line. let it ring a few times. if the phone rings, but not the fax machine, check the cord of the fax machine and replace it. if the fax machine still does it, there is a short circuit somewhere in the machine. it is most likely in or around the jack that connects it to the phone cord, check for corrosion or bent contact pins.
if it rings only once or not at all, then check the phone jack for corrosion. trace it all the way back to where your phone line connects to your house. if it is still not ringing, call your telco to get them to check thier equipment.
Jan 15, 2009 | HP LaserJet 3055 All-In-One Printer
I have a HP 3110 All-in-One Printer.Fax.Copier cannot get the drivers to down load so that I can print stuff from my computer to paper
Please go to this link and select the Operating System of your computer then download the driver for the HP Photosmart 3110 All-in-One Printer.
Sep 13, 2008 | Office Equipment & Supplies
Can't send or recieve faxes
Step three: Use an analog telephone service HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service. To obtain digital services information or support, contact the telephone service provider or system administrator.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
K80 OfficeJet has trouble distinguishing fax and phone ring tones
I would suggest getting a new one, but BE SURE you check to see if it will work with VoIP. I have the HP 6210 and it has problems with VoIP as well. Go to a place where you can test it at home and be sure you can return it if it has issues. Best Buy, or Staples are pretty good with returns, but SAVE the receipt! LOL... Sorry I couldn't offer better news! //Don
Apr 24, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
183 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
