Question about US Acoustics USX-2050 Car Audio Amplifier
Principle diagram of 2050 transistor amplifier
COULD YOU PLS HELP ME
KONZERT AV-502A KARAOKE AMPLIFIER,POOR AUDIO,2-RESISTOR WORN OUT PLS. HELP ME
pls check burnt resistors, if ceramic it's value is .25 0hms 5 watts, if big carbon film resistor it's value is 10 ohms 3 watts. check also power transistors A1941 & C5198. also check driver transistor A940 & C2073
Jan 06, 2013 | Car Audio & Video
What kind a outputs transistor use a QSC Gx3 power Amp
this power amp uses 2SA1962 and 2SC5242 output transistors. You can download the schematic diagram from this website.
Thanks.
gylacz
May 10, 2012 | QSC GX3 Amplifier
I haves an amplifier SONY TA-F210 to repair. The four "final" transistors are take out and miss. I haves no ideas of witch kind of transistors need. Please I need the list of component (or the...
You can download the manual included schematic diagram from here:
http://elektrotanya.com/sony_ta-f110,f210.pdf/download.html
When you use the link you get to a page where you have to wait some minutes to be possible the downloading.
Thanks.
gylacz
Aug 04, 2011 | Sony Audio Players & Recorders
Sony Amplifier, Sony CD Player, Sony AM/FM Tuner, Sony FM Stereo/FM-AM Receiver, Stereo Cassette Deck........I need to know how to connect all of these components so I can use the stereo system...........a...
The actual task of hooking up a home theater may take a little time, especially if you are doing a custom installation with lots of separate components, but following 3 links have the basic principle of input and output...pls visit all and than you can easiliy connect all properly..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
The Basics of Home Theater:
Sample Wiring Diagrams
http://www.prillaman.net/ht_info_8-wiring.html
Home A/V Wiring Diagram
http://www.unicom.com/blog/entry/521
How Do I Hook Up My Home Theater?http://hometheater.about.com/od/hometheaterbasicsfaq/f/htbasicfaq7.htm
Jun 22, 2011 | Sony Audio Players & Recorders
I dont know how to make this project.
Hi there
What sort of input levels are you using, and what is the amplifier to drive. A speaker, or is it just a preamp, or headphone amp?
Let me know and I will be able to help you.
regards Graeme
Jul 10, 2009 | Audio Players & Recorders
Dia Gram
www.stereomanuals.com
Feb 14, 2009 | Yamaha AX-396 Amplifier
Have a a7 Hc... Blown transistors.. Shematic diagram??
What are the part numbers on the transistors you replaced?
Did you replace transistors in the output section and the power supply section?
Does this amp have the defaced ICs labeled B52 and F16?
Jun 21, 2008 | Cadence A7 HC Car Audio Amplifier
US Acoustics USX-2050 Car Audio Amplifier Logo
268 people viewed this question
Top US Acoustics Car Audio & Video Experts
xxxxxx xxx
Are you an US Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
