On/off switch broken and programme faulty
The on/off switch does not work and we have to switch it on and off directly from the mains plug, but this causes the central fuse in the house to trip.
Also, the programme stops at the pre-wash, and we have to turn the dial on to the next cycle for it to continue.
Please could you advise what the solution would be, and what parts we would need for replacement.
    Scholar:
  • 111 Answers
Looks like you need the on/off control switch assembly.
Posted on Nov 24, 2008
Gas gauge flutters backfires when starting
Hi Anonymous, and the usual suspects are:
1. Loose, corroded, or broken battery cable ends inside the cable harness especially the "NEGATIVE" cable at both ends.
2. A severely drained battery.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
Good luck and have a nice day.
Oct 14, 2015 | GAS Motorcycles
Motorcycle won't start. Stalled out, backfired trying to restart, now nothing?
Hi Guitarfield, and the usual suspects are:
Apr 17, 2015 | Motorcycles
Back firing
For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2001 Aprilia Pegaso 650
Apr 22, 2014 | 2001 Aprilia Pegaso 650 i.e.
Low speed esitation
DOWNLOAD 2003 Aprilia Rst 1000 Futura
Mar 10, 2014 | 2003 Aprilia RST 1000 Futura
Backfire carb
Hi Binuya, and the usual suspects are:
Untitled Document
Jul 03, 2013 | 2009 Adly Thunder 125
]98 zx1100 wont idle and backfires when starting
Hi Terrance, and the usual suspects are:
1998 Kawasaki Motorcycle Service Repair Workshop Manuals
Nov 17, 2012 | 1996 kawasaki ZZR 1100
What does e 62 error code refer to?
E62: Overheating during washing this is real ans now iam giving u more tips abt error -
E11: Difficulty in filling during wash phase
E13: Water leakage.
E21: Difficulties in draining .
E23: Malfunction of drain pump triac.
E24: «sensing» circuit of the component (triac) that controls the drain pump faulty
E33: Incongruence between closure of anti-boiling and 1st level contacts of pressure switch
E35: Water level too high
E36: «sensing» circuit of anti-boiling pressure switch faulty
E37: «sensing» circuit of 1st level pressure switch faulty
E39: "HV" «sensing» circuit of anti-overflow pressure switch faulty
E40: Door open, Interlock, wiring or main PCB
E41: Door open
E41: Problems with aperture of door
E42: Problems with aperture of the door
E43: Problems with the triac which actions the door interlock
E44: Door closure «sensing» circuit faulty
E45: Problems with the «sensing» circuit of the triac that actions the door interlock
E51: Motor power triac short-circuited
E52: No signal from the motor tachymetric genetaror
E52: No signal from the tachymetric generator
Procedure for checking commutator motors
E53: Problems with the «sensing» circuit of the triac which powers the motor
E54: Motor relay contacts sticking
E61: Insufficient heating during washing
E66: The contacts of the heating element power relay are always closed
E71: NTC washing sensor faulty.
E82: Error in reading the RESET/OFF position of the programme selector.
E83: Error in reading the programme selector code
E93: Incorrect machine configuration.
E94: Incorrect configuration of washing cycle
E95: Communications error between microprocessor and the EEPROM
E96: Incongruence between control panel version and configuration data
E97: Incongruence between selector version and configuration data
EA1: Drum positioning system (DSP) faulty (top-loaders only)
EB1: Incorrect mains frequency
EB2: Mains voltage too high
EB3: Mains voltage too low
E32 INCORRECT CALIBRATION OF ANALOGIC (ELECTRONIC) PRESSURE SWITCH. IF THE MACHINE IS DRAINING OK, THEN IT IS THE SWITCH
E32 relates to the electronic pressure switch, normal pressure switch,inlet valves,poor water mains pressure and finally the main control board
E90 means theres a fault on the main control module so A;will need a new control module or B; get an engineer to try re-configureing the module
May 16, 2011 | Hoover Washing Machines
Can my key be reprogrammed in the ignition
The electronic key which you have only need to programme once, then it will work till get faulty not necessary to re programme there are only one way to re programme, it's only can do with new electronic ignition switch replacement so if you replace new ignition switch insert your key in it and it will take few minute for programme it take all the programme automatically then you can turn the key and start the car,
If you don't have replace the ignition switch but key is not working it's faulty either key or electronic ignition switch, if you have any other additional key if the car start with that key it's very clear it's faulty your key which is not working give me more details do you have the other key and only not working one key like that, however first replace the battery for your key and try if not work put a comment i will give you more details,
Nov 12, 2010 | 1999 Mercedes-Benz E-Class
Washer wont work
Does the programmer move or make noises?
It could be one of four things
Faulty programmer (if it does not move or make noises)
Faulty Door lock, (try pushing the door firmly in)
The belt may be broken - If the belt is broken or come off of the wheel then you will be able to see this by removing the top. (always make sure that you remove the electrical plug before investigating)
The brushes on the motor could be worn down
Nov 22, 2008 | Candy Washing Machines
Hotpoint WT960 Fault F-07 heater relay
A few reasons for this, faulty heater, broken wire, faulty pressure switch or faulty main control board (the heater relay is on the main control board).
There is no reset for this.
Unplug the appliance and take the rear cover off.
Check the wiring to the heater and thermostat. Give the wires a good tug as they can break internally and look ok.
If you have a multimeter, test the heater, it should read around 25 ohms.
Take the top off the appliance, locate the pressure switch (has a thin tube on it), give it a few good taps with your screwdriver handle.
Finally, take the main control board out (bottom left when viewed from the rear) and one plug at a time, take them off, clean and tighten them, plug them back on.
If everything checks out ok, then it's likely the main control board is at fault.
Good Luck!!
Thanks
Nov 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
