Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf000
How do I take the clip off and does it go back on easily, I am struggling to get it off.
    Novelist:
    Champion:
  • 244 Answers
Yes what clip
Posted on Nov 25, 2008
  • Hotpoint Master
  • 3,463 Answers
Hi.
What clip are you referring to?
Cheers
Posted on Nov 23, 2008
How do I remove the clips from the pump
I found it easier to hold one part with a Pointy nosed pliers and push the plastic grip out the side of the clip.
As it is plastic it just ratchets back into place.
Jul 14, 2014 | Hotpoint Aquarius WF000 Front Load Washer
Where is the filter on a hotpoint aquarius 1000 washing machine
The filter is underneath the machine,tilt it backwards look underneath and
you will see a rubber pipe with a plastic inner with a clip on the end.
Undo the clip and slide the filter out.
Apr 06, 2010 | Hotpoint Aquarius WF000 Front Load Washer
On my Hotpoint Aquarius WF000 1000 spin there are two lights flashing, one of them is the Time Delay ligh and the other is the Crease Reduction light, does anyone know why this might be occuring?
Try this out, it's for another hotpoint model:
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Would be good to check out the pump too
Mar 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Need to clean fillter on hotpoint wf000
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Would be good to check out the pump too.
Mar 21, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius Wf000
have u put the outlet hose to the floor to c if the hose is blocked if the water comes out then it could be your pump if it doesnt then take the washer outside cause when u do take the sump hose off it will flood your kitchen the clip is a screw clip at the top off the sump hose which is close to the middle of the outer drum
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wf000 aquarius
if the drum moves slightly up and down then your bearings are in need of replacing u can also check this by going to the back and taking the little cover of in the centre of the back check around the centre of the spider wheel if there is a mucky water mark then they do need replacing this will cost from £90-£150 to replace love
Nov 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 - water problems.
have u tryed to clean the fillter at the back of he machine
Jul 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
89 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
