Question about Refrigerators
Am fitting new thermostat to my bosch larder fridge have fitted everything but have misplaced the paper with the connection of wires grey and black have looked at unit but would rather be safe than sorry
  • oppo Nov 22, 2008
    benimur thank for that both wires goes to the to the green light which tells you the fridge is on what it did was try the terminals and watched to see if fan is working and have now found a connection which works the fan which is also working intermittently and seems to be working so ill carry on with this but thanks for your help eveything counts anyway would have had the wife test it he he he british sense of humour.........
  • oppo Nov 22, 2008
    a good five quid spent yes thanks for the helpand the guy benimur confirmed my conclusion
  • 135 Answers
If there are only 2 connections on your thermostat you wont do any damage whichever way you put them on, one way it will not run the other way around it will. If it has more than 2 connections let me know what make the thermostat is as connections differ.
kind regards,
Posted on Nov 22, 2008
    Brigadier General:
  • 6,966 Answers
Initially, if the gray and black wires both go to the thermostat, then it would not matter which goes to what terminal as there is no polarity nor the thermostat require specific wiring. If however, these wires go elsewhere and not the thermostat, then perhaps you can post back the exact model number so as to ascertain with its corresponding wiring diagram.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 23, 2008
    Thank you for using FixYa and appreciate the rating.
Why is Hotpoint RLA64T Fridge freezing up after new thermostat fitted?
Make sure that the temp probe from the thermostat is located exactly where the old one was. If it had a plastic sleeve on the old one, the new one will need that sleeve. You shouldn't need to calibrate the control if it is the one specified for this model. If it was a generic replacement then possibly it could need some adjustment.
Aug 02, 2014 | Hotpoint Refrigerators
New door fitted on Larder integrated fridge but door alarm sounds inspire of door being closed.Digital display indicates door open.
The old door had a hidden trigger that signaled when the door was closed.
You need to retrieve the trigger from the old door and fit to the new door.
Mar 31, 2011 | Electrolux Refrigerators
I have a Bosch KTR16A20 larder fridge which is either not cooling enough, or else it's freezing the contents! I assume the thermostat is faulty, ( I have checked and cleaned the radiator ) and am...
As you have described yourself as an electronics engineer, you should know that when thermostats go down, they fail. Thermocouples on the other hand can go strange but easy ones first.
Check the wiring continuity to and from the thermocouple.
Fridge and freezer help
Feb 18, 2018 | Bosch Classixx KGV28323 Bottom Freezer...
Hotpoint larder fridge RL150G keeps freezing at the back fitted n
flap controling tempature not closing to controle tempature 9inside ref
Dec 09, 2009 | Refrigerators
Bosch larder fridge KSR stopped cooling - has been diagnosed as thermostatic probe broken - now been informed this cannot be replaced? Is this true? The negineer claims that the fridge is no longer...
if he means temp sensor he is correct as they are foamed into the liner in manufacture you would destroy the liner to reach it however there are repair kits available for some models which bypass faulty sensor and allow it to run on ambient sensor you will need to check with bosch tech dept to verify this.
Nov 10, 2009 | Bosch Refrigerators
Fitted tall larder fridge freezing up on the back wall what is the problem and how do l sort.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Refrigerators
Larder fridge running far too cold
I was told that it ispossible for a snall pin in the thermostat to stick and that vigorously turning the knob up ad down a few times might well unstick the pin
Tried it and it worked!
Jan 03, 2009 | Refrigerators
Vauxhall zafira towbar wiring diagram.
what make of towbar wiring kit was fitted ? You can get a Whitter grey (S) fitting kit but this connects to their own black (N) wiring kit I would think any supplier of the N wiring should be able to supply a S kit.
JB
Nov 07, 2008 | Car Audio & Video
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
